Raspberry Pi 5 DSP crossover music streamer
My asound.conf file has only two lines
pcm.default pulse
Ctl.default pulse
Sudo raspi-config has pipewire selected, Labwc selected, and audio output to Loopback selected.
On the Pi5 gui desktop audio option (the speaker Icon) I have Loopback Analog Surround 7.1 Output active.
Today I connected my Pioneer VSX-32 AV Receiver with ethernet cable to my home network and configured it to use DHCP and obtain an IP address automatically. This is the same network that my RaspberryPi5 is connected to. I use a bash file to power on the VSX-32, set the input to BluRay (where my Pi5 connects with HDMI cable), re-initialize CamillaGUI and CamillaDSP, and play the Radio Paradise main mix with mplayer all with a single command by executing the bash file from the command line.
Your RaspberryPi will need telnet installed for this to work. To my surprise telnet was not included in Raspberry Pi Bookworm by default.
~$ sudo apt-get install telnet
Create a bash file in Linux using the nano text editing program. You can create a script called "scriptexample" from the command line prompt as follows:
~$ sudo nano scriptexample
This will bring up the nano text editor.
Enter the text you want in the nano text editor
Follow the directions at the bottom of the editor screen to save the file with a name and exit.
Make the scriptexample text file executable (chmod) by all users (+x) with the following:
~$ sudo chmod +x scriptexample
Now you can execute the bash file with the following (include the punctuation ./ in front of the filename)
~$ ./scriptexample
The bash file can be edited later without needing to repeat the chmod command.
You can also point a web browser at the Pioneer VSX-32 IP address to bring up its web page which allows a graphical interface.
You can also telnet directly into the Pioneer VSX-32 from the command line.
~$ telnet 192.168.##.##
Trying 192.168.##.##...
Connected to 192.168.##.##.
Escape character is '^]'
give the connection a few seconds. Then you can use the keyboard to enter codes consisting of two characters.
?V
Should elicit a response from the VSX-32 such as
VOL74
Which corresponds to a volume of -43.5dB on the VSX-32 front panel display.
A response of E04 indicates that the command is not recognized.
Enter ctrl+] to break the telnet connection and type quit to exit telnet and return to the command prompt.
telnet> quit
I hope this info is helpful to anyone out there trying to get network automation to work with their Audio equipment. There is still life in these old multi-channel AV Receivers from the early days of HDMI. And these units (with pre-outs!) are available dirt cheap now on Craigslist when they don't have 4K. Combine a vintage +/-2010 HDMI 7.1 AV receiver with a pair of old 3-way (or 2-1/2 way) tower speakers and wire each driver directly to its own channel on the AV receiver and CamillaDSP set up correctly to do the audio crossovers in software and you can really have a surprisingly good sounding system for next to nothing cost wise. Good luck!
The next step is to do the same thing with RaspberryPi5 over a USB adapter to RS-232 connection on the Pioneer VSX-32...
Connected the Pi5 to the RS-232 port on the Pioneer VSX-32 with a female x female null modem adapter from Amazon and an old USB/RS232 adapter cable. The Pi5 recognized the USB adapter automatically as /dev/ttyUSB0
I installed communication program screen.
Set baud rate with screen /dev/ttyUSB0 9600
Now the Pi5 powers up the VSX-32 with screen /dev/ttyUSB0 PO
All the other commands used over IP work over RS-232.
Use Ctrl+A and K to exit screen and return to the command line.
Very cool combination of "vintage" (can't quite make myself call ~2010 era vintage just yet) and modern stuff.
It's not really used anymore apart from sometimes connecting to legacy stuff like with your use case. The protocol being unsecured/unencrypted has little place in a modem environment.
Yes, agreed on the unsecured nature of telnet.
There were a few bugs in the script file that I attached previously.
FN25 should be 25FN to set the HDMI to BD (BluRay)
0005S should be 0005SR to set the Listening Mode to Pure Direct
Also there is no need in the bash for a break command or a quit command. This is only necessary if you telnet direct from the command line.
Success connecting the RPi5 to the Pioneer VSX-32 over RS-232. See bash script below.
#!/bin/bash
#This script sends commands via /dev/ttyUSB0 to VSX-32 RS-232 port from RPi5 with USB-to-RS-232 converter.
#The Pioneer VSX-32 RS-232 port is male. Use female x female null-modem adapter to connect a male RS-232 cable.
SERIAL_PORT="/dev/ttyUSB0" #your USB-to-RS-232 adapter may be assigned a different port depending on your connected devices.
BAUD_RATE=9600 #The Pioneer only communicates at 9600
stty -F "$SERIAL_PORT" $BAUD_RATE raw
sleep 1 #Sleep to allow RS-232 time to wake up and respond after every command
echo "Sending data to $SERIAL_PORT at $BAUD_RATE"
sleep 1
echo -e "\r" > "$SERIAL_PORT" #carriage return
sleep 1
echo -e "PO\r" > "$SERIAL_PORT" #Power On
sleep 1
echo -e "25FN\r" > "$SERIAL_PORT" #Input=BluRay
sleep 1
echo -e "0005SR\r" > "$SERIAL_PORT" #Pure Direct Listening Mode
echo "Data sent." #Confirmation echo to command line
Problem: rePhase FIR filters don't have the expected crossover point when loaded into CamillaDSP.
Using free program rePhase tab 'Linear-Phase Filters' I have created FIR filters for
High Pass 2khz Linkwitz-Riley 24dB/octave
Low Pass 2khz Linkwitz-Riley 24dB/octave
Low Pass 300hz Linkwitz-Riley 24dB/octave
On every filter I use 65000 taps, format=24 bits LPCM mono (.wav) with all other options as the default.
(FFT length = 131072 samples, centering = middle/use closest perfect impulse, windowing = hann, optimization = none to -100 dB, rate = 44100hz.)
These filters are all copied to the RPi5 folder ~/camilladsp/coeffs and loaded into CamillaDSP as new (+) filters of type= Conv subtype = Wav. I use these FIR filters to substitute for the corresponding IIR (biquad) filters which are 4th order Linkwitz-Riley in CamillaDSP running on the RPi5. With the same crossover points and slopes, any differences between the FIR and the IIR filters should be related to phase, provided the FIR filters are constructed properly.
The filter gain curve plots correctly in the rePhase window with 6dB down at the Crossover Frequency. However CamillaDSP tab Filters >plot shows the Crossover Frequency for a 2khz Low Pass filter as 6dB down at 9khz instead. The same thing (ratio of about 9/2) happens on the 2khz High Pass and also the 300hz low pass filter. And even my old ears can definitely tell that the FIR filter was basically muting the tweeter, and forcing the mid and woofers to play way too high hz.
I have now generated the rePhase FIR filters with Crossover points at a multiplier of 2/9 so that instead of the crossover point at 2000hz, I used 450hz. And for the crossover point of 300hz I used 60hz. Now the filters plot correctly in CamillaDSP and my ears are feeling much better! The FIR and the IIR filters are sounding much more similar Critical listening will be needed to compare them. See .png format CamillaDSP plots attached. CPU with FIR is averaging 14%, with IIR (biquads) was averaging 1.9%.
In any event I suspect the 9/2 ratio in the expected vs actual FIR crossover points has something to do with the rePhase parameter selections.
One additional note I realized. My initial listening test with the "original" FIR filters was directly on-axis at my usual listening position about 9ft away from the speakers. Working on my PC I'm near field (3ft away) and 45deg off axis from the right speaker. With the FIR filters applied, the tweeter was essentially muted below about 7500hz, my 8in woofers driving up to 9khz beaming like crazy and on-axis I was still hearing the highs on-axis. But off-axis all the highs vanished with the (uncompensated) FIR filters. The IIR filter was giving normal off-axis performance from the tweeter (2khz high pass) and keeping the 8in woofer where it belonged 2khz low-pass. (my speakers are Klipsch KSF-10.5 with horn tweeter and dual 8in woofers sharing the space space).
Compensating the FIR crossover points restored the speaker performance and the off-axis performance is back to "normal".
When listening to your speakers in an A/B comparison, I suggest on-axis and off-axis listening. Off-axis can reveal major problems you might not notice on-axis.
Found mistake in the FIR filter and corrected.
I have CamillaDSP capture rate set at 192khz.
The rePhase FIR filter must use the same rate.
I originally had the FIR filter rate at 44100.
Setting the rePhase Linear-Phase Filter rate = 192000 hz has solved the issue.
CamillaDSP response plot question.
I have CamillaDSP 2.0.3
pyCamilla2.0.2
Backend 2.1.0
In the Camilla GUI Filters tab, I plot my FIR High Pass 2K filter (RePhase linear-phase High Pass Linkwitz-Riley 24dB slope 2khz) and it appears as expected. No phase shift and no group delay.
But in the Pipeline tab when I "Plot Response of this Step" it shows the gain curve correctly, but phase and group delay are a mess.
Is this just a bug in the filter response plot?
I’ve been using an RPi 3B as a DSP for years. My sound card is an Asus Xonar U7. After running into issues with an SD card, I recently migrated the operating system to an SSD. To prevent power-supply problems I now use a powered USB hub. Music is played through spotifyd, which I control with the app on my phone or tablet. With a bit of help from a language model I’ve managed to make the whole setup plug-and-play. At the moment I’m using a Seas 27TFF for the highs, a Tang Band W8-1772 for the midrange, and a Focal 10V516 for the bass. I take measurements with ARTA, using the sound card as the input.
Helpful tips for verifying/swapping channels for audio:
Open /usr/share/pulseaudio/alsa-mixer/profile-sets/default.conf in a text editor and find the entry for your device profile (in my case [Mapping hdmi-surround71]
You can change around the order of the channel-map = front-left,front-right,....etc.
Just make a copy of the original channel-map as a fall-back.
You may need to do this if you have a filter file configured in CamillaDSP and you are not getting sound from a particular channel, on the wrong channel, or if sound from a channel is "bleeding" over to other channels. With Patience and a combination of reordering the channels in the /default conf, and relocating your speaker wires to different terminals on your Receiver will ensure proper channel matching.
In my case I have the receiver FRONT driving the Woofers, SURROUND(side) driving the Mids, and BACK(rear) driving the tweeters. My CamillaDSP has channels 0,1 assigned to the Woofers, 4,5 assigned to the Mids, and 6,7 assigned to the Tweeters. Channels 2,3 are muted.
My default.conf file has channel-map = rear-left,rear-right,front-left,front-right,side-left,side-right,front-center,lfe
This doesn't seem to make sense with for a channel map order assuming sequential 0,1,2...8 but it does work. Kind of an oddball thing I guess.
Another helpful tip discovered today.
From time to time you should use your CamillaDSP GUI to mute channels and confirm your audio is going where it is supposed to be. You could be losing a channel or having channels being output from incorrect drivers and not be aware of it with casual listening. This can also happen if you are using different programs to play audio. I was using VLC and the audio would have correct channel assignments, but Mplayer would not. I don't know if OS updates are affecting the RPI5 audio, or if it something else. But I've specifically been having both tweeters drop out and the right tweeter channel bleeding into the woofers. And its been driving me nuts. I suspect the OS updates are reverting the Audio icon properties back to a default 5.1 surround setup which will not work properly with the 6-channels active.
For my system the Audio Icon Loopback Device must be set to Analog Surround 7.1 but this does not appear to take effect until the RPi5 is rebooted. On the RPi5 home screen, I have had success with rebooting after making adjustments to the Speaker Icon.
For channel mapping I made the following edits to the default.conf file I mentioned in previous post.
[Mapping analog-surround-71]
channel-map = front-left,front-right,side-left,side-right,rear-left,rear-right,front-center,lfe
and the same mapping for
[Mapping hdmi-surround-71]
Helpful tip for those of you who may be suffering apparently random occurrences of CamillaDSP sending audio to the wrong drivers following a RPi5 reboot:
I am using the "official" RPi5 HDMI cable direct to my Pioneer VSX-32 but I am forcing
/boot/firmware/cmdline.txt
to use a custom EDID with this legacy hardware since I am using Labwc (in sudo raspi-config) which does not support the interlaced resolution display options of this receiver.
I have observed from multiple RPi5 reboots that the HDMI handshaking is not always successful or "clean". Whether or not a clean handshake occurs appears to be random probability successful maybe 20% of the time. This can be seen on the Pioneer VSX-32 display with the multi-channel icons [L] [C] [R] [SL] [SR] [XL] [XR] [LFE] flashing associated with audible pops from the speakers. The flashing and pops slow, and then stop eventually. Apparently the RPi5 is trying to reestablish the HDMI handshaking and the display flashes while this is occurring. Just because a connection appears to be established does not guarantee that the audio connection protocol will be the desired PCM multichannel 7.1 surround.
As an alternative to time consuming reboot of the RPi5 or cycling power to the Pioneer VSX-32 in order to get a "clean" HDMI handshake, it appears that simply changing the Pioneer VSX-32 to a different input and then back will reestablish the HDMI handshaking.
I suspect that failed or incorrect handshaking with PCM "other than" 7.1 surround (such as 5.1) explains CamillaDSP directing audio output to incorrect drivers because the channel assignments are different.
Updated to CamillaDSP 3.0.1
Updated to the CamillaGUI-backend to 3.0.3
pyCamillaDSP is at ver 3.0.0
This is running on a Raspberry Pi 5 with the latest updates.
There appears to be a bug in the CamillaGUI where in the Pipeline tab, when adding a Filter, an error message pops up with "channel unexpected." Apparently this bug has been an issue in the past as there is some existing message traffic on the diyAudio forum.
It is possible to directly edit the .yml file using a text editor such as nano. This is necessary by CamillaGUI forces you to select a channel when adding a Filter to the Pipeline. You cannot "unselect" a channel so that they are all blank. Below is my .yml file which also includes biquad filters which I have not applied in the pipeline.
When you generate a .yml file from "New Blank Config" in the Files tab, add your filters, your mixer, and add your Pipeline filters. CamillaGUI will show errors because it will add lines to the Filters section with channel: <number> which you will need to replace with null, as well as in the Pipeline section it will improperly format the filter channels. With my FIR Filters the line channel: null remains, but for biquad filters the line is deleted entirely. You may notice in the Mixer section i have dest: 6 and dest: 7 as muted: true because these are either Center or LFE (on my 7.1 surround AV Receiver) and would otherwise bleed into channels 0-5. The first filter in the Pipeline section I have in bold. This is the proper format needed to be edited manually from the buggy script which the CamillaGUI will generate. The other filters in the pipeline need to be the same format. With the .yml reformatted and saved you will see in the CamillaGUI Pipeline tab the filter being unassigned to any of the channels. The channel assignment for the filter in the pipeline will be active on the filters listed in the .yml file.
File Contents below
description: ' '
devices:
adjust_period: null
capture:
channels: 2
device: hw:Loopback,0,0
format: S16LE
labels: null
link_mute_control: null
link_volume_control: null
stop_on_inactive: null
type: Alsa
capture_samplerate: 44100
chunksize: 4096
enable_rate_adjust: null
multithreaded: null
playback:
channels: 8
device: sysdefault
format: S32LE
type: Alsa
queuelimit: null
rate_measure_interval: null
resampler:
type: Synchronous
samplerate: 192000
silence_threshold: null
silence_timeout: null
stop_on_rate_change: null
target_level: null
volume_limit: null
volume_ramp_time: null
worker_threads: null
filters:
FIRHighPass2000:
description: FIRHighPass2000
parameters:
channel: null
filename: ../coeffs/HighPass2kHzLinkwitzRiley4thOrder24dBOctave.wav
type: Wav
type: Conv
FIRLowPass2000:
description: FIRLowPass2000
parameters:
channel: null
filename: ../coeffs/LowPass2khzLinkwitzRiley4thOrder24dBOctave.wav
type: Wav
type: Conv
FIRLowPass300:
description: null
parameters:
channel: null
filename: ../coeffs/LowPass300HzLinkwitzRiley4thOrder24dBOctave.wav
type: Wav
type: Conv
HighPass2000:
description: 2000hzHighPassLR4
parameters:
freq: 2000
order: 4
type: LinkwitzRileyHighpass
type: BiquadCombo
LowPass2000:
description: 2000hzLowPassLR4
parameters:
freq: 2000
order: 4
type: LinkwitzRileyLowpass
type: BiquadCombo
LowPass300:
description: 300hzLowPassLR4
parameters:
freq: 300
order: 4
type: BiquadCombo
mixers:
2to8:
channels:
in: 2
out: 8
description: null
labels: null
mapping:
- dest: 0
mute: false
sources:
- channel: 0
gain: 0
inverted: false
mute: false
scale: dB
- dest: 1
mute: false
sources:
- channel: 1
gain: 0
inverted: false
mute: false
scale: dB
- dest: 2
mute: false
sources:
- channel: 0
gain: 0
inverted: false
mute: false
scale: dB
- dest: 3
mute: false
sources:
- channel: 1
gain: 0
inverted: false
mute: false
scale: dB
- dest: 4
mute: false
sources:
- channel: 0
gain: 0
inverted: false
mute: false
scale: dB
- dest: 5
mute: false
sources:
- channel: 1
gain: 0
inverted: false
mute: false
scale: dB
- dest: 6
mute: true
sources:
- channel: 0
gain: 0
inverted: false
mute: false
scale: dB
- dest: 7
mute: true
sources:
- channel: 1
gain: 0
inverted: false
mute: false
scale: dB
pipeline:
- bypassed: null
description: Mixer 2 channel input and 8 channel output
type: Mixer
- bypassed: null
channels:
- 4
- 5
description: null
names:
- FIRLowPass300
type: Filter
- bypassed: null
channels:
- 0
- 1
description: null
names:
- FIRLowPass2000
type: Filter
- bypassed: null
channels:
- 2
- 3
description: null
names:
- FIRHighPass2000
type: Filter
processors: {}
title: Klipsch KSF10.5 2.5-way FIR crossover
After all of this debugging the CamillaDSP logfile is still reporting error when playing streaming audio with mplayer, or when playing music from USB drive with VLCplayer.
Capture device is stalled: processing is stalled
PB: Prepare playback after buffer underrun.
And this is associated with intermittent drop-outs on the audio.
More debugging required, but at least I got the filters straightened out.
You are likely using a 2.x version of the pycamilladsp-plot library. It needs to be updated to support the channel->channels change.
Reactions: PMental
