Hi Kees, have you taken your portable spectrum meter outside and measure at different locations before you accuse someone deliberately using RF energy directed at your home?
Also, did you try measure if there's an elevated RF field around your bed, would have been interesting to know if the claimed coil spring bed antenna anomaly is true.
In the past when I used mobile phones much more than these days it gave me intermittent high pitched faint tinnitus only on the air I held the phone at, especially if the phone call lasted ca 15 minutes or longer, and I have been always aware of not dialing up the volume too high up which is a common mistakes with headphones and earbuds.
So nowadays when I can, I use the external speaker on the phone and lay the phone down on the desk while talking, (the mobile phone microphones adapts to external use so don't have to shout!), it works very well, or alternatively using a wired earbud.
Wired headphones also causes high pitched faint tinnitus after prolonged use, in opposition to mobile phones in this case it appears on both ears.
Several years ago when I noticed this phenomena I put two larger ferrite blockers on the cable near the jack because I suspected the RF energy entered the headphones especially when listening to media directly from the PC which is a known HF noise source.
Later I found out it's the same when having the headphones connected to the audio amplifier.
One peculiar thing I noticed is, if I some times (happened many times) I listened only to one song or few while sitting in front of my PC I would some times forget the song had ended and kept the earphones on my head even for an hour before I realized it, much probably I was too much into what I did on my PC, maybe I am wrong but that's how I come concluded that wired earphones probably picks up RF energy and causes tinnitus after a while without any whatsoever sound played back.
The earphone wire in itself is a potentially perfect antenna to pick up RF energy.
Have been thinking of open the cans and solder in two ferrite beads on each side, both signal and GND, hopefully it will work. Same thing should be done with the mobile phone earbud too.
Nonetheless, as far as it concerns me I don't feel particularly bothered with above mentioned "problems", it's just my own observations and they are there, however, electro smog is nothing to dismiss out of hand, the future will tell.
Hi
I have no elevated rf field around the bed, because there is almost no radiation, only the ruckus mast do some -37 dB 5.8 Ghz signal who is not that strong, but it is there.
I have measure outside and inside, the home, it is stronger on one nabure then the other, and maybe it is even the smart meter, so I can go try by mother's home in other city of there is the same trouble to exclude.
I have try the forum of aariona manufactor of the meter but she do not activate it, a other forum for ham radai did also not activate so I can nmot ask how to setup the meter. I have done a measurement in mine home over the whole max sweep with the pc software who is also with it.
I do not use earphones, the high pitch in ears is now present, it dissapears when I go to mine mother, who lives in a old concrete manufactorer building who is rebuild as apartments. she has wifi so the small sticks people use do not cause trouble, I have a cable though.
I do not like to put ferrite on the cable of the scope for measurement to get interfenrece out, the signal strength nabure was is illegal in mine eyes, industrie systems (a ruckus costs 2700 euro) need not to be here, as ruckus say it are special for industrie area, hotels, hospitals) but the Netherlands do always put industrie above people wel being, maybe people has to go faster to durable products like we do here already for years.
I di just measure all frerquencies programmed, so al known transmittors in mine bedroom who is on top of the house just under the roof, all the signals are well down except the ruckus who do -37dB the rest like umts, gsm, wifi, etc is -65 to -80dB only mine home where I work is very contaminated with rf fields and radar. I do now here do fly chinooks and apache militairy helicopters, also here she fly until midnight, disrupt sleep of people who has to work, but these do not radiate radar.. Maybe a datalink present>? there are datalink transmitters who do that on very high frequency, or I can coming week get a friend who collect all kind of apparatus from old times and has also 25 Ghz spectrumanalyers, with picture tube.
picture is mine home with the pc software,
regards
Do KPN have any RF interference measuring service? In my country if you report that your TV or radio reception is disturbed by a suspected RF interference, they come to the site with a mobile measuring car, and spot the interference source. Then they force to stop such activity by law. You don't need to complain about any health issues (I think the regulations are not so strict there, and difficult to objectively measure), only bad TV or radio reception. Call them and they will stop it. They don't even enter your apartment, they measure on the street with a specially equipeed car with antennas, spectrum analyzers and all that stuff.
Mine tv and radio is fine, I have a dish outside who is outside the rf, but I have already mail them with the litle movie with the rf radiation, so I wait for respons.
regards
Don't take it offending, but if you can't prove it then it does not exists. I mean nobody will care about it until it harms their financial interest. And (don't take it for yourself) there are lunatics out there who have some kind of monomania and everybody laugh on them. So you need to prove 1. that your problem is real and 2. that it harms someone's (yours or your provider's) financial interest.
Any discomfort or health issue is not a good proof. And your high-tech measurements however obvious are for you, they are too technical for the authorities. I can tell you right now that they will not interested in your measurements.
But if you report that terrestial TV (DVB-T) and WiFi and FM radio reception in your house is disrupted (even if you don't use such services tell them you do so), they potentially lose you as a subscriber. No need to show them your measurements, don't even mention them. They will bring THEIR measuring instruments for which they believe. From that point it is their (KPN and/or internet provider) legal obligation to stop all interference at your address of subscription.
It's is exactly what you say, you are right.
However the signals are from mine nabure and a small company, and the radar signals do not belong here as far I now now, it is on purpose to radiate me.
I have won a case in 2006 with a gsm mast, the local goverment has to give me a other home the judge demand, and that is happened, because the judge say that hospital did see that sleep disruping is from that radiation, the judge did say it is not yet clear of it do harm, but the opposite situation that it do not harm is also not yet found, so he did give me right, to prevent further damage on mine health.
I have now made a other video and soon someone comes here, also the telekom come make measurements because it is radar of quit strong signals who do not belong in mine house. upstairs where I sleep is clean now, I do get low menatoline levels because of exposing on daytime in mine livingroom.
regards
I have now put foly on the wall where I watch tv, after some days I do sleep better, but it needs more, the WLAN signals however come through, but weakening somewhat, the radar signals do go down to -56 dB so not vissible anymore.
What I can do is put aluminium foly on the wall and after that put wallpaper over it, because if I do not it looks very bad al this reflections.
here is the measurement, now I have done the setup right, I have use 9 Ghz with a span of 400 Mhz. I have also measure on other places by friends 4 km away, also there are this signals present, here do fly apache helicopters and chinooks, these do fly low over populated area,s as a drill, every day, making a very chaking noise, the house chakes, but I ask if she do use radar, yes the do but these can not get into a home with so much strength, tyhe radar stations are 19 km away.
So I go make mine home radiant free, better then fight against it.
YouTube
After the beep I go measure WLAN after some minuteso on the movie.
YouTube
Hi all
It is a while ago that I did post about the nabure, the transmitter is gone, the owner has removed it, but I am not shure the nabure does use the transmittor to radiate to me, I have no meter to measure that.
I have strange things in the grid, when I switch on the amplifier, the lcd tv who has a pfc into the supply does go into a green screen and sound dissapears, this for just some seconds and is from that switching on or of, same for the dish receiver or the media plaver, when shut off light the mediaplayer does give a error having disconnect the harddisk unsavely.
I have let look the energy people at it, and he did mention if there is a transmittor active, so ask if here is a radio operator active somewhere.
Now I think on that nabure, when she does point the removed 5 watt wifi to me, I get radiated, she is that mad, but I have not problems so far, only the grid has problems with switching things on and off.
Maybe someone can free me of some questions if a transmittor can be a cause of this strange behavior, special the lcd tv who has a pfc, then there mnoest bu a uge spike when switching the amp or other stuff, maybe the impedance of the grid is faulthy, or to many electric cars hehe.
regards
regards
Hi Kees.
Yes the heavy duty aluminum foil does work for reducing em signals.
I lined my garage walls with between 2-3 layers overlapped, not grounded because it made no difference.
I get 7-10 db reduction in signal strength from my local cell tower which is about 150 metres away.
I also now have difficulty receiving wifi signal from inside my house 20 feet away and it transmits about 25 metres in free air.
A good way to use foil on the wall is to spray the wall with 3M super 77 adhesive and stick it right on the wall. Make sure its smooth and overlapping otherwise it looks like crap.
Good luck!
Good luck!
Over a half century ago, we had a shielded room at the commercial antenna company. It was a wood framed room on the factory floor and the walls & ceiling were made out of copper window screening. Copper was not as expensive then. Aluminum screening would work as well, but you can't solder aluminum sections together as easily as copper.
Ralph Morrison in his 1990 book "Grounding and Shielding in Facilities" spends much of a chapter on shielded rooms.
Several years ago I read an intriguing claim by researchers Örjan Hallberg of Hallberg Independent Research in Sweden and Ollie Johansson of The Karolinska Institute in Sweden who have looked into the correlation between electromagnetic fields and the type of steel coil spring beds that are so common in the western world, I tried to find the original article but couldn't find it, but maybe some of the following links can answer some of your inquiries.
Left-sided Cancer: Blame your bed and TV? - Scientific American Blog Network
Coil Spring Mattresses - Institute for Geopathology SA
ps. some language glitches...
nabure = did you mean neighbor?
ruckes = ???
jinds = ???
Very long time ago, but have to say that the mattress coil spring I have also thought of, I have one who has big springs,the mattress weight is quit high, I think easely 50 kilo,s with all that metall.
The antenne who did cause the trouble from neightbor (yes I have not completely learn english, I do learn only by typing, not school, so thanks for correcting.) is removed, but I think she does use it express by put it on from the home itself, this trouble person will never stop, only when I move out of mine house.
I hope I get not corona, for her, mine health is quite strong on mine 63 years of age but then I be contagious hehe, oke I hope I get not that cold, it is not something to get happy with.
I go earth the spring of mine bed, and I think to go buy a new one without springs.
Nice for the japanese people she sleep on the floor, have much less cancer.
regards
This stuff can work also oke. But Maybe I go move, because after the renovation of this house it fibrates, avery step a neighbor set it does fibrate, also with cars going by.
This is on the 18 to 30 hz region and it is quite irritating, it came after the renovation where the outside are putting a insolation layer of polystyrene stick on the wall.
So need a move some day.
The mattress I have is like this on the video, it is the same springs version, a older one, I have also electric blanked, but does not sleep on it when powered, did forget one day to switch it off and the result was a wakeup in the night complete tingling body and heart race. I does now always put it off, I use it because of atrosis, works very good against pain, in the summer I always get if off the bed store it.
It was a nice reading, I am curious what G5 does, special the 26 Ghz transmittors everywhere, maybe I have nowhere to go for protecting me.
pic about the doktor is a investigation done in a hospital, so here the prove I am sensitive. I have trouble with melatonin, Mine body sees microwaves as light and as such I make no melatonin.
regards
See there was a lot of action here, for me, I have be in hospital for research of the cause ofg sleep disorder, I seems to have low melatonin, the specialist doctor did ask if I close to a mast for mobile phones, he say that I see microwaves as light, therefore body thinks it is still daylight and as such making no melatonin.
The mast of the nabure is removed now, the owner is go to a other house.
The 5G who is coming and is everywhere also in streetlights because of the 26 Ghz wideband system I am curieus what it does with me, possible it does nothing because this higher frequentie can be just not that problematic, getting everywhere connecties is a challence for the company,s. I had always the idea of the wifi low power on every home to use that as local transmittors as you walk by your mobile phone just log on next, then next then next home for open spaces just use streetlights or small mast, in nature area, just use no signals, only the standart phone for as something happen.
- Member Areas
- The Lounge
- radiation in mine home from nabure.
