Quick question about diode symbol on PCB
Hi all. I am populating a PCB today and ran into a problem. I have to mount 4 on these on this PCB but don't know how to read the symbol to ensure the right direction. I've spent an hour looking on Google with no luck. It is 101 degrees out and I'm working in the garage so I don't mind the break.
For current parts, you can just google the part number, and a data sheet will be near
the top of the page. The part pinout ID is always in the data sheet. The variety of package
is typically indicated by the last characters (usually letters) of the complete part number.
STPS1545D.......TO-220AC.........bare tab
STPS1545FP......TO-220FPAC......insulated tab
STPS1545G.......D2PAK..............smt
The silk-screening is just the part outline as viewed from the top, normally, but here the thickness of an insulated tab causes confusion - the thin rectangle must be the tab, because most TO220 are bare metal tab.
But this is irrelevant as you should check the device and PCB layout to confirm the correct orientation (don't rely on the silk screening being correct).
