Question – why noboady uses MJ15025 and MJ15024 pair of transistors
Hi!
MJ15025 and MJ15024 OnSemi Samples:
Pedro Martins
Thanks for your pointer ..... QuaqYi. The problem is I can't find datasheets of the two transistors that provide me with the same transfer characteristic (Ic-Vce) graphs to make the comparison. Would deeply appreciate if you could post them to me. Many Thanks!!!:cheerful:
Im currently busy with a "vero-board" layout for the M250
Can i use TIP 3055 Output transistors ? my supply is +/- 50V and using the amp to power an 8 - ohm, 8 - inch woofer, with a LPF with an Fc of 3.1Khz so i dont need super fast tranistors, right ? can this be done ??
Thanks in advance for ur help !
That's a very big NO, unless you like the smell of burned transistors...
You shouldn't even consider comparing the TIP3055 with a MJ15024.
With a supply of +/-50v you would exceed the max rating for 3055 by lightyears !
Mike
, eem is there a cheaper transistor then when i mean cheap i dont mean FAKE transistors heheh just a lower and cheaper version may a plastic case?? if no then i`ll use the MJ`s then eem heheh
the reason why i want cheap ones is cause like i said the load will be light 8 - ohm , with a bandwidth of 20 - 3.1Khz ,and the amp wont work very hard but when i do decide i will put better output transistors in place,also my sub subwoofer is my next which will consisits of x2 M250amps running in brige mode
with the TO-3 metal cases no finance cuts on that sub woofer project.
Thanks for ur input ppl !
