Question about Paradigm PreAmp, and DC Input toDH-200 & Hsu Sub
I need assistance with a question about a new (to me) Paradigm preamplifier and whether its direct coupled output can be used with an unmodified Hafler DH-200 or with a Hsu Research VTF-2 subwoofer without potentially damaging the amp or speakers.
I have scanned several threads on modifications and tweaks for the Hafler, and I have the original manual and schematics, but can't read them to know if there are input capacitors or a servo to handle DC input. I built the amp from a kit over Christmas, in '79 or '80.) I've also searched the Hsu website without success for the same kind of information on this question.
I've enjoyed reading some of the threads with members like Dick West who know a great deal about the Hafler.
Any help would be appreciated. I do have much to learn. (My first step will be replacing the original output capacitors in the Hafler, which I just ordered this afternoon.)
Dan
Dan
Thanks for the kind comments.
Do you have a VOM? Have you measured the DC offset of your preamp?
The DH-200 has an input cap that, among other things, blocks DC from getting into the amp, DC that may come from the preamp. This is pretty much standard practice.
As long as C1, the 10 mF non-polarized cap, is on the circuit card and functioning
you will be OK to use your preamp.
Hope this helps. It is good to be safe rather than sorry.
But, here is a possible problem. Have you measured the DC offset of your DH-200? These old amps have no DC nulling circuit and many, over the years, have come to have DC offset problems. The first 4 input transistors, in the differential amp circuit, must be matched to each other on hFe. Sometimes these transistors drift out of spec or get damaged by too high input potentials. If so, you could have DC offset at the output of your amp.
Let us know about your DC offset readings of both the preamp and amp outputs.
Got the offset measurementsrequested (finally!)
Just completed the testing suggested, and found that the DC offset at the preamp outputs were measured as 0.0 mV's, right and left.
With the preamp outputs connected to the DH-200, the DC offset measurements for the amp outputs were:
-54.2 mV's on the right channel
-11.7 mV's on the left channel
The MM test leads were connected red to red, black to black on DH-200 outputs, and red to inner lead and black to outer ground on RCA pre-outs.
I went back to the Hafler DH-200 kit directions and learned that the input transistors, which can be causing the DC offset, are not identified as such in the materials.
I am interested in learning how far "off" these numbers are, and what the next step should be.
Thanks!
Dan
Thanks!
Dan
The amount of DC offset you measured is low enough to not cause any major problems. Don't worry about it. Some "experts" say that anything less than 100 mV DC offset is OK. Personally, I like to keep it below 50 mV. I have measured some old DH-200 amps and found they only have 10-15 mV of DC offset. Your readings are acceptable.
The transistors that can cause DC offset are Q1 and Q2, and Q5 and Q6. Q1 and Q2 should match each other within 10% on hFe. Ditto for Q5 and Q6. The Hafler manual for the DH-200 did not comment on all of this because it was not supposed to happen, the modules were built and tested at the factory. However, over the years, some of these 4 input transistors may drift out of spec and because they no longer match DC offset will occur. This is a frequent problem with these old DH-200 amplifiers.
The DH-220 included a little circuit to null DC offset. The DH-200 does not have this circuit.
Anyway, it seems you are OK with your project. Good luck.
Dick
Dick
DC Offset Thanks
Dick,
Thanks! I plan to replace the output capacitors with 27K uF's as the first "mod"/upgrade.
Dan
Dick,
Dan
I would not call them "output" capacitors. They are power supply filter capacitors. Before you install these larger value capacitors you might want to read some of the threads here about "inrush current limiting." The power switch on your amp may not withstand the added demands of inrush current required to charge the larger caps you intend to install. You may find your ON/OFF switch will burn out or its contacts may get welded together. Later versions of the DH-200 and other Haflers used a huskier switch. Good luck.
Dick,
Thanks for the information. I had the power switch replaced about ten years ago though I can't say whether it will be up to the demands of the situation you describe. I'll do the search you suggest and see what may need to be done.
Dan
Dan
So the next question for this DIY newbie is, where does one insert the 2 ohm inrush current limiter into the AC mains circuit in the 220? Can it be placed in parallel with the 5 amp slo blo fuse? Should it be inserted into the other lead that runs to the power switch? Is there some way to solder the item that involves the power switch? All help is appreciated.
Dan
Dan
Your amp has two Thermal Breaker switches, one attached to each of the two heat sinks. If you trace the wiring to these two switches you can discern that it is really a "loop" of the incoming AC supply. Just unsolder one of the two wires that goes to one of the thermal breakers. Then, insert the thermistor in series with the AC by soldering one end of the thermistor to the now vacant terminal on the thermal breaker and solder its other end to the AC wire freed when it was unsoldered. This will put the Thermistor in series with the incoming AC and by doing the wiring as described you can leave the thermistor hanging free in the air so it can cool as best possible.
Easier to do than describe. Keep your connections as short as possible but don't try to cover them with heat shrink tubing. The thermistor will get hot.
....for every answer there's a new question, but I want to get it right the first time.
I have found several manufacturers of these thermistors, of various sizes and specs. There are some that are 2 ohm or very close (e.g., 2.5 or so) but their amperage limits vary a great deal. The slo-blo fuse in the AC circuit on the DH-200 is 5 amps but that means it may spike higher for short periods.
There's an inrush current limiter from Ametherm that is rated 2 ohms/5A, or should I go with higher amp ratings allowing for the sudden rush of current, in a 2 ohm or 2.5 ohm ICL? Some are rated/tested as high as 18, or 25 or even 35 amps for 2 ohm or 2.5 ohm ICL's. My guess is that the ohmage (my word....as opposed to homage, which is a different thing altogether) is the key spec, while one wants a little more rated amperage, but can the current rating be too high and keep the device from performing its function in my DH-200 application?
These are a lot of words for a 2 buck part, though the amp is worth much more, obviously.
If you decide to reply, thanks in advance, Dick!
Dan
Dan
It is proper that you are concerned about protecting your amp and getting things correct -- the first time.
Some experts state that one does not need to worry about current limiting until the capacitance in the PS exceeds 30,000 uF. You are adding two 27K uF caps for a total of 54K uF. The inrush current is a very time limited event as the caps will be charged 30-50% in the first split second and their inrush current will diminish after that. Therefore, you only need a series resistance for a short time and in this short time not too much heat will be generated. Even most switches and diode bridges can tolerate a short for a split second.
Not only do the caps look like a short to the AC supply at turn-on so does a large toroidal transformer -- until its magnetic field is created. But, chances are you do not need to do anything for your amp if you have a newer switch rated at 25 amps. The early DH-200 amps had a flimsy switch that routinely failed. Later versions of this amp had huskier switches. The DH-220 has a huskier switch. You originally stated you have a DH-200 but later referred to a DH-220. Which amplifier do you have?
I routinely turn on a DH-220 with a pair of 27K uF in its PS and nothing has failed yet (fingers are crossed). I also use a pair of monoblock amps that contain 80K uF for *each* channel. This pair of monoblocks I turn on with a time delay relay that places a 50 ohm 50 watt resistor in series with the incoming AC set for the first 7 seconds . A thermistor is a "quick fix" but even when it heats up it still leaves a residual amount of resistance in series with the PS which could impede, ever so slightly, the ability of the PS to keep its caps fully charged during transient musical events.
If you have read the several threads here about all of this you have come to appreciate that inrush current limiting can be complicated or simple with no "best" solution for all applications. Here is my recommendation:
1. Make sure your power switch is rated at 25 amps and ignore current limiting, but be prepared to possibly replace a switch sometime in the future. Professional versions of the DH-220 (P-225/P230) have push on connectors to their switches so the switch easily can be replaced. Whenever I replace a switch I attach push-on connectors to the wires that go to the switch.
2. Use a CL-30 thermistor and rest easy. A CL-30 thermistor is recommended for your application.
3. If you use more than the pair of 27K uF caps hook up a time delay relay and very husky surge resistor which is switched out in a few seconds as the relay times out.
Good luck
Good luck
- Question about Paradigm PreAmp, and DC Input toDH-200 & Hsu Sub
