Question about baffle placement and box volume
Hi
I'm in the midst of building my very first speaker system, and I'm not quite sure about the enclosure.
I'm mainly uncertain about whether should the baffle be on the outside or on the inside, or in other words, should the baffle dimentions be the actual HxW or larger on each side by twice the thickness of the MDF?
Is there any general acceptation as to how it's best to construct the enclosure in that aspect? Which sides are to be in, out or on top of which?
And lastly, would sinking the entire baffle (about 0.7 cm), affect or distort the response?
TIA,
Jonathan
EDIT CONCERNING BOX VOLUME:
My drivers are SEAS 27TDFC (http://seas.no/seas_line/tweeters/H1189.pdf) and
L18RNX/P (http://seas.no/seas_line/woofers/H1224.pdf). According to my caculations the Volume is to be 10.8 Liters, and this, taking the drivers' diameters into account, calls for a 25x43x11(cm) box. Are my calculations correct? could it be such a small box?
Jonathan
Another thing I've been meaning to ask (although I'm sure it will show me for the newbie that I am): inductors, as I know them, are large gauged copper wire things. Yet what I was given when I went to buy some for my original design of crossover were tiny objects, very much like small resistors, marked with that color code. Am I missing something here? could it be due to the values of those inductors (0.5mH and 2mH)?
thanks,
Jonathan
Just another Moderator
Joined 2003
Just use simple math W X D X H = volume of the box... this should be the internal dimentions. Rule of thumb is to add 10% to the volume to allow for displacement of drivers, bracing etc.
so once you have the internal dimentions just work out which way you are going to join your cabinet sides, top, bottom back and baffle, and add the necessary amount for the thickness of your MDF. Do a drawing it will help :)
Tony.
Yes, as I have said, I alredy have the dimentions of the box. My question was whether these dimentions appeaer reasonable considering the drivers' parameters.
And I gather there are is no general consensus as to the the way the box should be constructed?
Jonathan.
Joined 2003
Sorry Piro I misinterpreted your first post, probably should go to bed ;) I had a late night last night, and going back and re-reading your first post it shows ;)
With respect to how to do the baffle (and a completely non scientific approach), probably whatever way you find easiest to get it to seal well :) how accurately you can cut your MDF will influence this the most.
Tony.
Okay.
How about the drivers' locations? (their distance from each other and from the edges of the baffle).
Also, I've determined the width of the baffle as 5cm more than the width (diameter) of the woofer. Again, is this o.k or is there special importance to the baffle's dimensions?
thanks again,
Jonathan
Joined 2003
piro said:
Okay.
summary put the drivers as close to each other as possible, and try to mount them a little off center (both height and width wise) for more info check out this recent thread http://www.diyaudio.com/forums/showthread.php?s=&threadid=61364
thanks again,
Jonathan
baffle width will determine at what freq baffle step (do a search lots of info in here) starts to happen at, also the width is (supposed) to effect the imaging with narrower widths supposed to image better. There are differing oppinions on this last point. I think that the above thread has mention of the edge and the baffle diffraction simulator in it both of which can be used to simulate baffle step, and the BDS being able to simulate difraction effects as well..
Tony.
edit: the edge wasn't linked, here it is http://www.tolvan.com/edge/
edit2: oh and one other thing, you shouldn't have any of your dimentions (W D H) the same, or it will tend to cause problems with standing waves.
piro said:
Okay.
thanks again,
Jonathan
well one way of joining sides i did was a rabbat i think it was so strong i stood on it and no internal bracing just need a router or dato set tho
right.
Here's another one:
My baffle is the outer-most sheet of MDF' meaning that it's larger than the inner dimensions in both it's hight and it's width.
When I work with BDS or Edge, should I use the inner or outer dimensions for simulation? The reason I ask is that I'm pretty sure the margins do not vibrate (at least not to the same extent as the rest of the baffle), yet the sound wave dosent "break" till it reaches a physical edge.
thanks
Jonathan
P.S
It might be worth mentioning that I intend to chamfer the edges of the baffle.
well, I have modled my enclosure using BDS and Sketchup (a trial of which may be found here).
I'd be greatful if you could take a look and give me your c&c (comments and critique).
TIA
JOnathan
Edit:
in BDS;
Load the profile, basic and advanced freq support, then:
set to quadruple sampling,
edge to Chamfer,
source to Combined, and type as Separate.
Only then press "Recalculate".
  • enclosure data.zip
Joined 2003
Hi Jonathan,
Looks like you have BDS under control :) Only suggestion would be to try increasing the size of the chamfer. 2.5cm would probably be a good starting point... will tend to reduce that initial dip in the woofers response.
I didn't look at the enclosure because I don't like having to put details in to download a trial version of software.... but I think you are on the right track :)
Tony.
