That will increase crosover distortion
Of course, adding the baxandall diode implies adding a third diode into the biasing strip.
Many improvments can be done on this amp, but I want keep basic schematics, work great like old Dynacord. Many amplifier based on this schematics was made latter.Of course, adding the baxandall diode implies adding a third diode into the biasing strip.
Yes, 2SC2922 is better than 2N3773,apex
sir, can i used 4 pairs of 2sc2922 instead of 4pairs of 2n3773???...tnx...😕
TIP35C can be used with +/-45V DC rail voltage orhi apex, can i use TIP's? 🙂
TIP3055 with +/-35V DC rail voltage, two pairs is enough,
how much power can i get with these pairs in full supply...say +-65dc???...
tnxxx...
550W on 4R load is maximum power from this amplifier.how much power can i get with these pairs in full supply...say +-65dc???...
tnxxx...
whoa!!!😱...this amp really is powerfull for begginers!!!...😀550W on 4R load is maximum power from this amplifier.
Powerfull but simple, for me amp is amp no metter how powerfull it is.whoa!!!😱...this amp really is powerfull for begginers!!!...😀
Useing with protection circuit, no problem, if you like how it sound. You can try it with single pair outputs, it's simple, have a fun.Hi apexaudio
550 watts use for mid-high pa line array no proplam ?
Thanks, be welcome if my expirience is usefull for you,You are a real diyer's gold mine.
For single pair 2N3773 use +/-40V DC rail voltage.
O.K.
I will start with 2 2N3773(old "RCA" labeld types). First i have to find the right transformer in my basement.
regards
frank
550W is maximum power for this circuit, not with +/-65V.550 W with+ /- 65 V dc
Regards zeoN_Rider
With +/-65V DC output power will be about 250W on 4R load.
Old 'RCA' is very valuable parts,O.K.
regards
frank
- QUASI Amplifier for Beginners
