Quantum Audio QCA4000D
Amp is using IRF1010's for power supply fets with 47 ohm gate resistors..
The drivers are C2383 and A1013 ..
Im gonna replace the fets with IRF3205's since the 1010 are defective,,
The drivers are also defective..
Would the BD139's and BD140's work as good subs ??
Replaced all power supply fets and drivers..
If i power the amp up it will idle fine for 1 to 2 mins then draw excessive current and the transformer will start crackling and popping ..
If i twist it i can watch the current draw increase and decrease..
I cant find a short in it..
Also not sure if the transformer would cause this but the power supply driverboard get very hot when the amp draws current..
Should i unsolder 1 side from the board to see it i can find the short or whats the best was of doing this??
Heres a couple of pics of the power supply
I got the amp to idle fine for now..
Problem im having with it now is i have 2.03 volts on pin 8 of all op-amps and have 53.6 volts on pin 4 of all op-amps..
The regualtors are D669A and B649A ..
Pins 4 and 8 of the op-amps connect to leg 1 of theese Not sure if this is normal or someone has them in backwards..
If this is normal is there a good replacement for them??
The D669A doesnt read at all the meter stays on OL at all times i trippled checked this but cannot get a reading ..
The B649A tests fine..
Heres what i get on the pads..
B649A
Pad 1:-72.6
Pad 2:-72.6
Pad 3:-0.6
D669A
Pad 1:0.00
Pad 2:64.5
Pad 3:0.1
DZ1 appears to be the diode for the positive regulator. The striped end connects to pin 3 of the D669.
The other zener connects to pin 3 of the B649.
Check the diodes. It appears that both are shorted.
It also appears that you have a solder bridge between pins 1 and 2 of the B649 transistor's pads.
