I don't think that that diode could be damaged through a 10k resistor (the only thing, except for possibly a capacitor, connected to that diode with the transistor out of the circuit).
Confirm that there are no solder bridges between the base and collector pads of the regulator transistor.
Ok for the D669A on the pads i get
Pad 1:0.00
Pad 2:21.6
Pad 3: 14.6
For the B649A on the pads i get
Pad 1:0.00
Pad 2:-27.4
Pad 3:27.3
For the D669 transistor i installed a 1N4744A and get the correct voltage on pad 3
For the B649A transistor i havent installed the diode yet and get 27 volts on pad 3 is this noramal or do i have a problem somewhere??
Pad 1:0.00
Pad 2:21.6
Pad 3: 14.6
Pad 1:0.00
Pad 2:-27.4
Pad 3:27.3
Ok now i get -14.56 volts on Pad 3 for the B649A transistor..
And i get 14.79 volts on the 3rd pad for the D669A
Heres what i get in diode check for the B649A
Legs1-2 Legs1-3 Legs 2-3 OL in all posistions..
Probes reversed i get
Leg1-2:OL
Leg1-3:0.606
Legs2-3:0.606
Heres what i get for the D669A
OL in all posistions with probes reversed i get OL also i cant get it to read anything..
As soon as i stick it in the amp the diodes blow..
So im guessing this is defective..
Is there any good Subs for theese 2 transistors??
Leg1-2:OL
Leg1-3:0.606
Legs2-3:0.606
Sorry..
I meant to say that as soon as i power up the amp it blows the diode for the -15 volts..
When i went to check the -15 volts on the op-amps i was only getting -2.82 volts but i discoverd that it blew the diode again ..
So im not sure why this amp keeps blowing the diodes for the -15 volts
The diode connects to legs 1-3 of the rectifiers also..
Wondering could one of theese could cause the diode to blow if it was leaking??
I don't see how you could have ±15v on the base pads for the regulators and then the diode fails. It would be more likely to destroy the regulator transistor if there was a load fault causing the failure.
Did you use continuity only to determine that the zener connects to legs 1 and 3 of the rectifiers?
- General Interest
- Car Audio
- Quantum Audio QCA4000D
