The board without wax
Removal of the old diodes:
Enlarging the holes to fit the new diodes in:
The new Philips BY 228 Diodes soldered in place:
Completed board ready to be covered with beeswax:
The beeswax-cube I picked up in a honey-shop is being melted:
The completed box:
Making new patch cables for the unit by hand:
silver plated copper 1mm solid core wire insulated by PTFE ribbon used by plumbers covered by and additional heat shring tubing:
I replaced the old neon with a new one of the same size, 6*20mm
The procedure of soldering the solid core patches:
I sourced titanium m3 screws and nuts for the replacement of rivets for fixing the phenolic selector board.
For some reason, I decided to stay with uniform white color for all the patch cables
Finished EHT unit:
Will look something like this:
Troubles redoing the 8mm diameter hole in the back of the audio transformer.
The previous owner 'drilled' a larger diameter hole to accomodate a larger and 'better' input sockets, but he removed them after selling the speakers and refitted the OEM plugs those were wobbly in these holes. So, I had to redo the holes with some method.
First, I had used some 'commercial 'epoxy putty, that fell out every time, and had limited durability regarding heat. I had a luck to obtain some nice high temperature putty that stayed in place at least after the drilling and painting too.
Time to refit the windings into the box:
I simply covered the holes with cellotape, filled the box with hot wax, and carefully slid the whole block into it. I had no troubles with the earthing, the four screws on the top managed to get in contact both the box and the transformer's housing through the excess wax.
This is the epoxy I used with success: (sorry for the advertisement)
The finished audio transformer:
- Planars & Exotics
- QUAD ESL 57 A little work on the loudspeaker
