Pure Evoke Flow Internet Radio
Pure Evoke Flow
Found this thread this morning, glad I did.
Hi, I have a Pure Evoke Flow which I bought around July 2009. Same thing happened to me with display started dimming earlier this year, contacted Pure and same thing, £70 etc, not very helpful to be honest. Can barely see display now, not happy as it cost about £140 at time of purchase, seems to be a common issue with this model from what I’ve read on the internet.
I’d be interested in a display unit please. May see if I can get someone to fit it locally as had it apart once trying to check if the connections were secure and think replacing might be beyond my capabilities.
Many thanks.
Justin
New to this forum, which I found in search of a replacement display to my radio, I came across this excellent source.
I would therefore like to join the "Badly in need of a Pure Evoke Flow display" - Club.
I will need one display sent to Denmark.
Noigardo
Many thanks.
Justin
Replacement is really easy, main thing is to get a torch to see where the ribbon cable goes into the connector, there is a tiny tab on each side of the connector which effectively jam the ribbon into the connector. these tabs need popping up and the ribbon just slides out.
Unscrew the 4 tiny screws securing the display back plate and lift out the display.
Gently peel off the copper backing shield and stick it to the new display.
Gently fold the ribbon over the back of the display and post it through the guide slot (which is stuck to the copper).
Refit, push ribbon into connector, push down the tabs, refit the back of the radio, turn it on, have a beer. Saved yourself loads by doing it yourself and rejuvenated a perfectly good radio.
Cheers!
I have fitted the new display without peeling off and reapplying the copper backing from the old display. To me the new display looks fine.
Could you let me know what function the copper backing performs; I have the old display still so it would not be too much trouble to re-do the fix if it's really necessary!
It provides RF shielding and heat distribution, however - I'm not sure how essential it is.
