Pumpkin preamp - ordered by Steen , official making thread
If you connect your scope across R7 of the Shunty, you will be able to see the current waveform as a voltage.
Just make sure the Shunty 0V is not connected to earth, because the scope probe ground connection is earthed.
After DCB1, i have appetite for shunty regs. How would you guess your shunty perform against salas' SSLV1 BiB? I now have great respect cor both opinions an ddesigns. Your regulator seems to do more on the eseries element of the regulator, adding to wonders of shunt portion. KatieandDad, your at fault, sorry, but i would bet money on it.
I have finished my four shunty and pumpkin boards.
The shuntys work perfectly.
The pumkins have this problem: releved at the output of three of output cap DC wandering under 100 mV. Removed one of the 4,7 uF MKC and with the bypassed little MKC cap DC at output wander around 2 mV.
Tryed other plastic cap and always DC rises proportionally at cap value.😕
Only one C4 output shows DC zero value
What do you think about that?
Thank you.
Ciao,
Anto
Thank you.
Ciao,
Anto
