Good ones, and look brand new btw.
The odd part is that i bought up the entire stock they said they had left, the minute i saw their ad, that was before 2010.
Need a datasheet, an image of the integrated amp they came out of, or a close-up(s) of the tranny ?
(cough, me pay less than $21, mucho less)
I emailed again asking to ensure availability and sure enough they dont have any now, despite saying they did a few days prior.
This may do the job
220V 50W R-core Transformer X-Former 45V-0 0-45V 0-25V | eBay
pics of Real Mc-C
Split core and split windings blend-in well with your character, yer trannyness.
Serb Man you Fracture, i suppose ?
(50VA-R is 1/3d weight/size, more rational if it's a single box drop-in)
Help
I have assembled my Shunty and Pumpkin boards.
Tested the Shuntys with 400 ohm resistors. Obtained +/- 36V
Hooked up Pumpkins.
One channel works as described in the setup section.
On the second board the negative rail drops to -17V.😕
Any thoughts where I should begin to troubleshoot?
Thanks in advance
Best
Bob
Hooked up Pumpkins.
Thanks in advance
Best
Bob
Hi Choky
All LEDs are lit on the Pumpkin
Positive voltage = 36V
Negative voltage = -20V
Bob
Bob
check ( either with diode or ohm range on your DMM ) between GND and neg leg ;
also check D-S ( diode test) of Q6 and Q8
compare with good channel
disconnect Shunty while measuring
Shunty disconnected
Good board Neg to GND 10Mohms 1.63V
Bad boy 10kOhms 1.63V
Good board diode test D to S Q6 qnd Q8 1.7V
Bad board Q6 and Q8 .7V
Bob
Bob
try to desolder one of them ( either Q6 or Q8 ) then measure
if bad measurement stays , desolder other one and repeat ;
now is tricky
it seems that you can exclude possible shortie on pcb , because you measured 10K from neg leg to gnd ;
so - reason must be that some part is conducting excessive current when power is applied .
do this : dismantle heatsink , power up and observe which of those 5 mosfets is excessively heating ; 4 of them must have similar temp , and Q10 must be (almost) cold ;
off course - for start you must be sure that you don't have some wrong resistor there
in any case - fiddle with diode meter here and there ( between pins of each transistor , same as between pins and gnd ) , comparing differences between working and non-working channel , and you'll localize what's wrong
now is tricky
I was measuring resistance and found on the board that works
R5=R6 =16k measured across each in circuit and
on the board that doesn't R5=R6 =100k
well - if Papa is honored , count that I'm double ......
thank you doubly 🙂
- Pumpkin preamp - ordered by Steen , official making thread
