steenoe said:
Hi Mr. Magura.
That webpage of yours is turning out pretty nice.
Thank, it's still under construction.....and it seems it will be for quite a while, it takes a lot more work than I though it would
Magura
Magura said:I think we better leave this challenge for the designer
Magura,
My suspicion is on very high secondary voltage. The DMM needs new batteries and the reading cannot be trusted, which I will fix this evening. The high voltage probably destroyed the electrolytic caps (C2, C15, C16) which resulted in high currents through the resistors which blew it. Although there was no smoke, I think, I might as well get ready to order more caps.
Dinesh
dviswa said:
Magura,
Dinesh
Hi Dinesh.
Did you by accident connect the secondaries, wrong? It has happened before. Check the secondaries with your DMM (AC) to see if they are connected as they should be. It sounds like you could have two "hots" connected to one side of the psu.
Steen,steenoe said:Did you by accident connect the secondaries, wrong? It has happened before. Check the secondaries with your DMM (AC) to see if they are connected as they should be. It sounds like you could have two "hots" connected to one side of the psu.
I had the tech drawing from Plitron, it is a little unlikely. But yes, I agree, I will check again tonight and make sure I did not mess it up.
No Fuses I meant, the fuses on the board after the bridge and CRC. What I was trying to do is to make sure I was getting right voltages from trafo and bridge. Everythingelse, Shunty and Pumpy were not yet in the circuit. I have a fuse on the primary, which also blew out.Magura said:The key word here is as far as I'm concerned "FUSES" as in NO fuses.
Hehe, do I have a choice?Magura said:Get yourself a handful of fuses, and try again after measuring the secondary voltage, BEFORE connecting the trafo.
@dviswa :
if you are using fusible resistors , sometimes they are more prone to burning than usual stuff ;
anyway - use 0W5 either carbon or MF with value of 2E2
I wrote that in Cook Book , in addendum ;
I have no these problems , because I use just 1mF caps in my Shunty , but sp300B was first who tell me for that problem ;
that's why I added that note .
regarding fuse in primary .........
be sure that secs are polarized/phased regularly , and that fuse isn't too dreky for xformer size.
Re: Re: Re: Re: regarding socks and sockets
AR2 said:Zen Mod said:
anyway - let us know your impression - what's difference in sound between shared (between channels) generic PS and this one ..... "complex"
Please do not let me describe the sound. It sounds rally good.
lazy serb
ya still owe us pics ......
I heard somewhere that you're good at it ..........
Re: Re: Re: Re: Re: regarding socks and sockets
Me too
Me too
And I know if he is good at it or not
Magura
Magura
Zen Mod said:@crazy danske metal-youngster :
"puttin' odd number of cigares in your nose isn't polite" ..........
so - be gentle and resize some of pics on your site ...........
It's on the ToDo list.....but it also takes time.....
Magura
Especially not if handing them out afterwards
Magura
you can always send them to me prior to uploading ,and I'll shrink them for ya .
it's really 30sec/pic jobie
Zen Mod said:@dviswa :
ZM,
Sorry I did not see it. I will fix the values when I reorder.
Good to know that I am not the only one.Zen Mod said:but sp300B was first who tell me for that problem ;
Zen Mod said:regarding fuse in primary .........
I verfied the connections and measured again. I am getting open loop 54-0-54 on the secondaries . Surely, way too high. I have requested the manufacturer to fix this, Let's see what comes of it. After that I have to order and replace all teh lytic caps.
Also noticed that my home supply is around 125V instead of the rated 110V
spavleski said:You can't be alone here
what's up dudengineer ?
(I'm hardly keepin' my eyes open ......... )
Workie, workie
spavleski said:
Workie, workie
Me too The pumpkin is getting a new home and bigger heatsinks , the case is with "see through lid"! Who could resist with all them green led's in there? Not me....
Now don't forget to write in Swedish on the front panel
Magura
- Pumpkin preamp - ordered by Steen , official making thread
