I am just getting into vacuum tubes, so the first thing that I will need is a test bench power supply for investigating different preamp circuits.
If I build a variable supply it will take me ages, so it makes sense for me to buy one.
I figure a variable supply up to 400V at 100mA, with a separate 6.3 V / high-ish current supply for the heaters. Does this sound sensible?
What would you recommend?
Are they available in the UK?
This elctrophoresis supply is great for doing that it's got 2 voltage ranges 0-600 and 0-2kv. the 0-600 goes to 300ma too.
You can find them on ebay for 50 to 60 bucks.
http://cgi.ebay.com/ISCO-Electropho...yZ111543QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Check that link.
Nick
But no 6.3 volt out though but that would be easy to put together.
Check that link.
Nick
Look on Ebay for a Farnell E350.
Keep your eyes out for a Heathkit IP 2717. I got one off ebay a good while ago and they occasionally turn up. It's got 6.3V and 12V heater supplies at a few amps apeice, variable 400VDC at 100mA (125mA peak) and a variable 100VDC at 1mA. There's V and I panel meters for the DC outputs.
It's also useful for reforming old caps too...
Had to replace the 4mm banana posts on mine as the threads had seized on a few, other than that it works fine with good clean DC outputs under load.
ChrisC. 🙂
ChrisC. 🙂
I very much appreciate your advice. I will be following up on the three recommendations.
Thank you to all,
Gordon
Thank you to all,
Gordon
There are also very nice supplies which were made by Eico, Hewlett Packard, GenRad, Lambda -- although chances of finding one of these in the UK are pretty slim.
- Tubes / Valves
- PSU for testing circuits
