Profet Amplifier
I see, the company called Class D manufacturing these devices ACD100NSD/ACD102PSD. How well the N and P channel devices are matched?
HI
I don't know , all I know after Renesans took over the manufacturing the Hitachi lateral mosfets I do not like them .
I never tested yet .
A have some 6 pair from Class D but I didn't did any test yet .
Before I used EXICON those are one of the best lateral if not the best .
I tested the Renesans in the ProFet , after I switch to Exicon heaven and earth the difference between them in favor of the Exicon .
At the class D company they wrote me these are close to the quality of Exicon .
I will see when I do some test .
But I need to make a enclosure for the amp after I can do some tests .
Greetings
gaborbela said:
The Iq to set up 400mA for the Grand Mos .
..... [/B]
400mA for one device or 400mA for whole amp?
I don't think about built this amp for now. I'am just curious. My problem with such amp is high idle current. With 2x50V, 400mA gives 40W - quite high. There is no any thermal feedback.
Also good mosfet are not cheap - another small problem.
But I cant stop thinking about this amp ...
Hello
I forget also U can run the amp in Class A/B mode .
These is a very high quality amp .
But if you want something more simple take a look at the Zenquito .From the same designer .
You can bias that in pure Class A or A/B to .
Much simple less parts and great sound if U use similar components like many DIY-ers did in France .http://pagesperso-orange.fr/jm.plantefeve/theo.html
You can open the site in English if you Google Zenquito DIY amplifier .
Hi
I too amp very intrested in the performance of the Class D lateral mosfets
They are made by Semefab. Semefab also make the Exicon and Magnatec Lateral Mosfets
I came across the Semebab specifications for the acd100nsd and acd101ndd Mosfets and it is different to the spec published by Class D.
You can find it here
http://www.semefab.com.cn/acd100nsd.pdf
http://www.semefab.com.cn/acd102psd.pdf
