Problems with hifonics brutus 1206d amp
ok like the tite says it its a hifonics brutus bxi 1206d i'm trying hard to find this part out ,people say its a driver but i don't know and help?
If no part of the blackened area caused the meter to change from whatever it reads with the probes not touching anything (no matter how close together the probes were), you don't have to cut the burned area away.
To replace the SMD parts, you'll have to use discrete parts as shown in the photos I posted. You'll need two 1N4148 diodes, two 220 ohm resistors and two MPSA56 transistors. You'll have to scrape the traces and wire the discrete parts as shown. The collector legs (leg 3) of the MPSA56 transistors are soldered to the ground plane on the other side of the board.
