ok like the tite says it its a hifonics brutus bxi 1206d i'm trying hard to find this part out ,people say its a driver but i don't know and help?
It's difficult to see in the photos. Are you referring to the transistors on the upper right corner of the board?
That is an amplifier.........
yes it is an amp
Sorry, I couldn't resist.
You need to clean the board to see how badly it's damaged. if it's extremely bad, you'll have to cut the carbonized board away and make point to point connections.
whoa hold on a minute boss go slow ,i know where you going but let me take the part out and clean it so you could advice me how to go foward
These (attached)?
If so, how badly is the board burned?
thats how it looks is there a way to go around it or to fix it?
Set your meter to ohms and touch the probes to the burned area. Place them as close as possible without them touching. Does the meter ever change from OL (or whatever it reads when the meter leads are not connected to anything)?
can you be more specific boss
What part of that needs to be more specific?
ok like you see in the picture not all is burned and by the way sorry to sound like very desperate i get really nervous when it comes to fixing car audio,
anyways you want me to turn my multimeter to ohms and test the burned part ?
Yes. If it's not an auto-ranging meter, set it to the highest resistance range.
ok boss did it but where all that is burned dont have resistence
If no part of the blackened area caused the meter to change from whatever it reads with the probes not touching anything (no matter how close together the probes were), you don't have to cut the burned area away.
To replace the SMD parts, you'll have to use discrete parts as shown in the photos I posted. You'll need two 1N4148 diodes, two 220 ohm resistors and two MPSA56 transistors. You'll have to scrape the traces and wire the discrete parts as shown. The collector legs (leg 3) of the MPSA56 transistors are soldered to the ground plane on the other side of the board.
- General Interest
- Car Audio
- Problems with hifonics brutus 1206d amp
