PROBLEM WITH MY MMATS D800.2
after you select post quick reply, you should see at the bottom it says additional options there is a box that says manage attatchments. click that, and it should as you for file you wanna add.
find it on your computer, and then select open/apply/attach what ever options it gives you. and you should be set
d800.2
hopefuly these pictures give you an idea of what i'm working with
