Proac response one crossover
Yes it asks the owner to have at least something to measure the capacitance.
I refurbished several loudspeaker with Alcap lythic...they Do drift and not at the same time when in serie and when //.
If Falcon shop has two 80uF in stock then not too much risky for the wallet. 33 + 47 = 80, those are often within 3% in real life : https://www.banzaimusic.com/Bipolar-Capacitors/
Drawing a shematic is easy just need to look the two side of the pcb and where go the wires...a 8 yo child can make it 🙂
Do not spend monney on mcap from mundorf or new binding post...wasted monney.
Ah the mundorf lythic...that is ok, they are the same than FT in the link above but less precise in the capacitance (more 10% than the marked 5%). If UK based, check Falcon Acoustics for Elcap brand. I was giving CE based shop just in case the op was on the continent cause postal from UK can be costly.
So Banzai music may be a good choice and they have mkps too...but they can be slow to ship...just write a message when ordering saying it is urgent or it mays take more than two weeks or three they wake up when it comes to ship abroad.
Sexy caps do not look so bad on the outside.
Reactions: tone?
