Preamplifier Stereo on PGA2311
Hello
As I finished the next preamplifier I wanted to share the project on the forum
The PGA2311 device is a high-performance, stereo
audio volume control designed for professional and
high-end consumer audio systems. The PGA2311
uses an internal high-performance operational
amplifier to yield low noise and distortion.
Device functions:
- Volume adjustment -95.5dB to + 31.5dB with a step of 0.5dB
- Volume control with remote control and encoder
- Balance adjustment (remote control and encoder control)
- Mute function (remote control)
-ON / OFF (remote control and switch control)
- Memorizing settings after switching off
- Real time clock + date based on PCF8583
-Cooperation with popular 2x16 displays with HD44780 driver.
- RC5 pilot (each Philips)
- Input select (5 sources)
The program was written in Bascom, it takes 51% of the memory
Fuse bits set on internal 8Mhz dnt forgot turnoff JTAG
ps.
I am asking for opinions what you think about such a device
YouTube
  • PGA2311-stereo v1.zip
Reactions: aditya
Mine is gathering dust, as its audio delivery is very poor in comparison to what I use.
Way to step on a guys hard work and offer no useful criticism just to plug your own kit. Come on now... is your intention to disgrace yourself?
OP:
Kudos to you. I haven’t used PGA2311 chips, but it looks like you’ve put a lot of work into it.
What’s the precision on the volume tracking?
Do you have gain or a buffer?
It has appeal to me as sort of a cost effective /minimalist amb a10 without too much in the way of sacrifice.
I’ve seen some similar implementations, one was a group buy I think here a while back.
I’m assuming you used that to inform your design? If so where do you attempt to optimize? What were your goals?
Could you post some performance measurements?
