"PowerDrive": how to choose the right MOSFET part?
Forgot to mention, the above has internal gate protection, so no need to add a zener to prevent gate breakthrough. Tests for capacitance done at 1MHz and 25V
This next one though has lower capacitance and no protection diode. I have some, but havent tested them yet.--
AOT1N60 Data sheet suggests 800mA, 600V, 41W P-Diss, Crss 1.8pF, Coss 14.5pF,--testing conditions as above, from datasheet.
When searching for mosfets or most semiconductors, I just use Digikey's search feature.
I have used the AOT1N60 and it works fine. I would recommend a 15 volt zener from gate to source to avoid incidents. I still have a bunch that I bought maybe 2 years ago.
I tend to prefer mosfets with insulated cases whenever possible. I tend to have exposed heat sinks in my test boards and either get zapped or spark things out when poking around. At the rate I blow up fets I gave up on insulators.
