You need to use the secondary ground when measuring voltage on the secondary side of the power supply.
The base of Q5 is driven by pin 1 of U6 through R25 and R32. The voltage on pin 1 of U6 was essentially 12v. It would be difficult to get anything more than 12v to the base (black probe on Q5 emitter and red probe on Q5 base).
Try this... Black probe on secondary ground. Red probe on each terminal of the driver board. Wiggle the driver board. Does the voltage on any of the terminals vary when you wiggle the driver board?
Ok something on the output driverboard is defective since when i pulled it the amp powerd up perfectly..
With the audio driverboard removed the D1302's still are being driven on ..
With the audio driverboard removed and black probe on leg 1 of D1302 and red probe on Leg 3 i get 0.60 volts..
what leg would i need to track back to see if i can find the problem?
- General Interest
- Car Audio
- Powerbass XTA500D
