Power transformer identification
Joined 2021
Another noob question from me:
I measured the greatest resistance at 77 ohms between the 2 brown wires at the top right, which are marked 130-0-130.
Would that be a valid primary in the US? How would I hook it up?
That is 120V AC line input on the two RED wires.
Winding resistance depends on both the wire gauge and length for that winding.
Gauge depends on the current rating needed for that secondary.
There are also other windings on that core, so the brown-black-brown secondary winding
must have less current capability than the primary, and has a smaller gauge and higher resistance.
The black wire is the center tap of the brown/brown winding. Each red wire feeds a diode rectifier,
and the black wire is grounded. This makes a full wave rectifier.
That's 120V AC line input on the two RED wires.
Gauge depends on the current rating needed.
There are also other windings on that core. so the brown-black-brown secondary winding
must have less current capability than the primary, so a smaller gauge, and higher resistance.
Thanks! I agree because that’s the only thing that makes sense.
Also, I think the marking on the PCB is incorrect. It should be 130-0-130 instead of 120-0-120, because that’s also the only thing that makes sense.
