Power amp under development
thanks quasi
i see the nmos 200 extending the output
but i see some resistor changes
i need you confirmation
what resistor should i need to change
regards
thanks,
why does the 10R resistor R1 discolor?brownies is there problem with my nmos 200-to247?the amp still working but noticed the color both channel the left & right amp R1 same discolor
thanks,
It should not discolour at all, so there could be something wrong with the amp. Have you measured the resistor and confirmed it is 10 ohm?
Cheers
Q
This is my nmos200 to220 irf840 amplifier.Working hard in various testing condition for 2 months.No problem so far.Thank`s quasi,great amp.
Yes we have improved QUASI AMP KIT
with VI Limiter - DC Triac Crowbar Protection - Balanced NE5534 OP input - Opto LDR Input Limiter all is complete in double layer PCB: 231 x 80 mm
its combined PCB design you can choose MOSEST or BJT in Output stage
we can produce in small quantity but we dont offer in market and dont offer in EBAY or AMAZON because no market for DIY AMP Kits
Which size have your PCB ?
Here is my latest NMOS PCB and schematic double layer,... size 231 x 80 mm
Did design it for PA ... excellent sounding amplifier
Complete NMOS amplifier PCB with...
Electronic Turn on Delay Relay free - DC TRIAC CROWBAR SPEAKER PROTECTION - VI LIMITER & Short Circuit Protection - BALANCED INPUT NE5534 IC with Volume Control - Overheat Protection - Input LDR Limiter thx an apexaudio
regards
regards
C21 and C22 must be 100pF not 100NF, triac no need heatsink,
VI limiter for nmos amp you can see here
http://www.diyaudio.com/forums/solid-state/162494-amplifier-motherboard-5.html
Schematic of ARCAM ALPHA 10
