Tack, Bo and thanks you guys.
It takes actually quite some time to administrate approx. 70 letters but to recieve money takes weeks although for 90% it takes only 2-3 days.
I'm glad you like the boards and I'll hope you will use them also. I don't mind pictures
It was fun to make this board because I haven't made a board in two years privately and one year at work.... that board was rather cool, 475 A, 4 x 140 um copper.
Possibly, but I'm not the right person in this subject.housing said:Hi all,
Is this type of choke coil from stripped down CNC Lathe machine suitable for SS power amp?
It may be worth mentioning that the heatsinks should be mounted approx. 1 mm above the pcb surface because the are "live" and the groundplane may have an another potential.
Mount the diode at the heatsink
Put a cardboard or something between the heatsink and the pcb.
Solder the heatsink. It's enough to solder with only a tin drop for starter if you of some reason want the remove the heatsink.
Solder the diode.
Remove the cardboard.
Solder the diode.
peranders said:Anybody using the board in a real amplifier? Pictures?
I have to find a real good amp to build if I'm going to use these PS boards. So for the time being, no pictures.
- Group Buys
- Power Amp PSU Board (for e.g. LYNX Amp)
