power Acoustic BAMF 5500.1d powes up no output
I got this amp for free but looks like someone has already tried to repair it. I have the same amp but is different. Posting photos. The one plays fine but the other powers up but no output. followed the signal to the driver board that uses IRS2110s. It has no modulation on pin 1 and pin 8. The signal seems to stop at the first TL072 and go square on pin 7.
Are these the origonal ICs. The outputs are also different FDA59n25.
Pin 3 and 11 both have -105v using speaker ground.
Sorry about the sideways pictures. My camera didnt want to work right with me.
1st picture is Pin 1
2nd is Pin 7
3rd is the driver board that i have.
Does your scope display a square wave properly? Those should be square. I don't know if it's your scope or the signal.
Attached are pins 1 and 7 as they should be.
Pin 1 drives the MPSW92 which drives the driver IC via a dozen or so other components. The collector of the W92 should have a drive signal that drives from the negative rail up about 10v.
Not sure what was up with my scope. Maybe time to clean the knobs. I bought it used at a local electronic supply house. After some fine beating the image was better. Have to adjust those rabbit ears with aluminum foil.😀
Attached is the correct readings.
sorry for not being in focus.
It's OK as long as you're not the one wearing the aluminum foil hat.
The combination of the two sets of images make it seem like it's OK. Mine were taken at 5v/div., 5us/div. and DC coupling. The drive for the W92 transistor is the one that is mainly below the reference. Are you getting a square wave drive to the driver IC?
For there to be modulation, you would have to see audio on pin 5 of IC172 and a triangle waveform on pin 6.
There is something going on. I am using a function generator for signal. Its output is at the lowest setting which has a output of .6v on the rca's. I have everything turned to the left(pic included). but with any adjustment to gain or crossover control the signal goes from pure to square, as in clipping. I am not sure what to make of that.
But I am getting the signals off of IC172.
Howerver I am not getting any signal to IC151 (IR2110s).
No drive signal on collector of W92. Just -105v.
The two images are W92 pins 1 & 2
The waveform does change a bit if i increase volume or decrease volume. More of a duty cycle than amplitude.
