Post Pictures of Your Vero Board Designs Here.
I'm always amazed by those early boards with computer chips and masses of wiring
on the back! I guess the speeds were low enough not to be a problem back then.
That's nothing, look at these actual production Cray photos. They had to measure each wire for proper timing.
And they were very fast at the time.
Seymour Cray's path to supercomputing - CNET
Some kind of color coding would have been nice !
@Doug: Thanks !
Yeah that's a bit worse than this beauty that I scored when we decommed our Facom M380. I think mine is more pretty though 😉 I was told the same about the wiring, the loops of wire being carefully trimmed for timing reasons. Supposedly the wires are enameled silver. Not sure about the gold..
Tony.
Wish I could find a spice model for 1J24Bs
As these tubes do not have grids this will be something....
I love these tubes as they are very versitile but some experimentation is required.
Please check this site (if you not already have):
Russian Subminiature Tubes
"Not sure what you mean by this, these are pentodes, 3 grids"
No grid whatsoever in these tubes..... beam deflection on each "grid"
And each connection or "grid" if you will, can be used as anode if you choose to...
There's a Cray 1 (and several later models!) near me at the Computer Museum of America in Roswell, GA. I saw the thing in a special preview before they officially opened. Yes, it has all those blue wires in it, and somewhere, I think at the bottom, they're all cut. It appears the wires had to be cut to move the thing. It's a shame it's most likely never going to run again (the electrical power it takes is tremendous enough), but then again you can surely get a full-speed Cray emulator in a smartphone app. Some other model(s) use some dangerous cooling fluids, and you wouldn't want to try to run them regardless.
This is my portable microphone preamplifier from 2004, with phantom power supply. The rechargeable battery needs to be replaced, but otherwise it still works fine.
I do not need a Zotl, just it would be nice as it is more compact (minus 2 output tubes as no SRPP). The anodes are directly connected to the stators as in conventional tube amp can be done. The advantage of Zotl is the "output transformer" (now only used as DC to DC up-converter) is also the HV "modulated" power supply,
Under the veroboard you can see the old amp.
