Post Pictures of Your Vero Board Designs Here.
Guitar Preamp with diode clip distortion (ESP).
This one is the sweetest thing I have made till now. Drives anybody who listens to its output MAD. Me included. 😛
Nice stuff Shaan 🙂 if messier is better then you should check out this one 😉 there isn't a decent pic of the board, but you can see some of it 🙂
also this one
It was a trigger circuit for my car alarm. Basically had a couple of SCR's which would (I think) conduct if the ground was removed, causing the caps to charge and set off the current sensing alarm 🙂
These are the two I mentioned in the ugly prototype and amp threads 😉
Tony.
Here are a couple more, neither still in use.
The first one I think was a voltage probe (for car electrics).
The second one was a mixer that I made for doing a uni project where we had to make a radio play. We used it for mixing recorded voice and background music. One of the pots was scavenged for some other use at some point.
Tony.
Another old amp
2006 Job. Recently brought back for replacement of two broken knobs...
Only the left most pot is used as the volume control... others for the gap filling.
Tiny chipamp from 2009
The smallest stereo amp I ever made on a dotboard. Power output 1+1watt 😀
Currently used for my older computer... casual listenning...
+-12V powersupply with linkwitz transform and 2 channel parametric filter and with balanced output for my bridged subwoofer amplifier
I did design a pc board but haven't had it built yet.
SPDIF switch
With multiple SPDIF sources and only a few inputs on my DAC, I needed a SPDIF selector switch. So I made one out of a handful of components. It has two optical and two coaxial inputs and an optical and coaxial output. Here it's in the prototype stage. Currently it's in a nice case with it's own transformer to eliminate the need for a wall wart.
