I have a pair of 10" JBL 2123H that I would like to use for midbass duties. These are high efficiency (101 db), low xmax (2.5mm) pro audio drivers. They drivers are very similar to the 8" JBL 2118 (97 db) which have been used with great success in some high profile SQ cars back in the 90's. Such as Mark Eldridge's 1987 Toyota 4-runner. Typically that application was sealed or AP.
My current plan is to use a .5 cu/ft cabinet tuned to 83 Hz. I will use an 18db electronic crossover at 90 Hz; the crossover point is not adjustable. My current plan is a .5 cu/ft cabinet tuned to 83 Hz.
My questions are:
-Is the placement of the port critical? My current plan was to place the port adjacent to the driver.
This thread was originally started in the Loudspeaker section:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=131549&perpage=25&pagenumber=1
My questions are:
what's the make for the car, and any general location of the boxes.
source's
amps?
EQ?
Bass woofer?
treble horn?
What sound/levels and music are you going for?
Any other info that might be useful or different?
source's
amps?
EQ?
Bass woofer?
treble horn?
Objective: There is no particular SPL level I am trying to achieve. Just clean dynamic sound in a noisy environment. In particular I am seeking very dynamic mid bass. In 1986 I got into a truck to listen to the sound system. The music wasn’t playing very loud; the sound was clean and crisp. Nothing exceptional, just very clean sound. But on some drum and bass guitar notes my shirt moved. You could feel the impact. It was veseral. And yet the music wasn’t loud, but when the midbass was needed, it was there. That is what I am going for.
Car – 20002 RSX, basically a Civic hatch back coup.
Tweeters – LPG 26NA, metal dome tweeters, Described as airy sound. XO @ 6.1K,
http://www.madisound.com/catalog/product_info.php?products_id=543
Location - Flush mounted in A-pillars firing at each other, 2 inches above mids.
Amp - Soundstream D100II (1991), 100 w/channel
Mids – Peerless 3” Wide Range; Described as transparent .xo @ 250 Hz and 6.1K Hz,
http://www.madisound.com/catalog/PDF/830986.pdf
Location – A pillars firing between driver and passenger
Amp - Soundstream D200II (1991), 200 w/channel
Midbass – JBL 2123, xo @ 250 Hz and 90 Hz,
http://www.jblpro.com/pub/obsolete/2123.pdf
Amp - Orion 280GX (1988), High Current, 40w/ch into 8 ohms
Location – Below rear window in .a sealed .6 cu/ft box
Sub – DIYMA12, Describe as transparent. xo @ 90 Hz, sub sonic at 29 Hz,
Amp - Orion 280GX (1988). High current. 360 w mono.
Location – Hatch in stealth box firing across the car right to left.85 cu/ft tuned to 31 Hz
DIYMA12. Specs
Fs: 25.21 Hz
Qms: 4.748
Vas: 41.71 L
Cms: 121.9 um/N
Mms: 326.8 g
Rms: 10.91 mohms
Xmax: 23 mm
Xmec: 32 mm
Dia: 25 cm
Sd: 491 sq. cm.
Vd: 1.129 L
Qes: 0.383
Re: 3.6 ohms
Le: 1.319 mH
Z: 4 ohms
BL: 22.07 N/A / Tm
Pe: 1000w (up to)
Qts: 0.354
no: 0.169
SPL: 84.3 1W/1m
HU-Pioneer PRS880 – Crossover and EQ
http://www.pioneerelectronics.com/p..._11221/300588614DEHP880PRSOperationManual.pdf
Built in auto EQ (with microphone) and adjustable crossovers at 250, 1.25k, 1.6k, 2K, 2.5, 3.1, 4k, 5k, 6.3, 8k, 10k, 12.5k @ 12, 18, and 24 db.
This HU is only capable of running a three way so I will cross the sub/midbass at the HU at 250 Hz and send the signal to a Audio Control 2XS to split the signal for the sub and midbass..
Audio control 2XS crossover - This will split the sub out put from the HU into separate sub and midbass signals .This crossover is set at 90 Hz with a chip. This particular crossover was chosen for two reasons:
-Orion GX amps can not be bridged without an Orion 400BDG bridging module, the Audio control 2XS unit has that capabilities built in.
-18 db subsonic filter @ 29 Hz.
At one point I was going to use a Coustic XM7 4 way Electronic Crossover and 5 band parametric eq but decided not to because it wouldn’t mono my sub amp and did not have a subsonic filter.
DIYMA12. Specs
Fs: 25.21 Hz
Qms: 4.748
Vas: 41.71 L
Cms: 121.9 um/N
Mms: 326.8 g
Rms: 10.91 mohms
Xmax: 23 mm
Xmec: 32 mm
Dia: 25 cm
Sd: 491 sq. cm.
Vd: 1.129 L
Qes: 0.383
Re: 3.6 ohms
Le: 1.319 mH
Z: 4 ohms
BL: 22.07 N/A / Tm
Pe: 1000w (up to)
Qts: 0.354
no: 0.169
SPL: 84.3 1W/1m
2-D200II's and 2-280GX's. Nice.
Do you have additional chips to play with?
Hey TS, I just have one D100 and one D200. One nice thing about the all four of these amps and the AC 2XS is that they all fit under my front seats.
I could get a 106 Hz chip. I had forgotten about that. I should buy that now so I have that option later incase I need it.
Hi
Alot of info to digest at the moment.
1) Any and all info (freq options) on the Xover "chips" schematics, etc. we could use!
Thinking we could design the mid BR box/ports to adapt to the Xover or a combination there of.
2) At some higher frequency the sound from the midbass ports would sound funky. Seems at 100 Hz you getting close?
3) Whats the plan for final EQ adjustments?
1) For the crossover from midbass to sub for the AC 2XS, I can get 72 Hz, 90 Hz (current chip), 106 Hz, 129, and 153 Hz. No schematics are avaliable. For the rest of the croosover handled by the headunit are programmed.
I was going to use the auto eq funtion as a starting point and tunig from there. I understand that the are harmonics of the midbass attack in the upper ranges that might need to eq'd.
BTW, the HU also has time alighnment.
Thank you for your time.
mitchyz250f said:Thank you for your time.
Your welcome. Good luck with your car.
edit> You can handle it from here?
PS You can add the 90Hz HP filter response to Unibox.
And after all, if the mid starts to distort due to port unloading, you can just turn the volume down.
Can you make recommendations for the crossovers for the midbass? I was thinking based on your comments I could tune the box to 83 Hz and crossover at 106 for some added protection. Does this make sense?
Can you elaborate on 'Thinking we could design the mid BR box/ports to adapt to the Xover or a combination there of.'
Did you want schematics of my system or the chips?
mitchyz250f said:Can you make recommendations for the crossovers for the midbass? I was thinking based on your comments I could tuned the box to 83 Hz and crossover at 106 for some aded protection. Does this make sense?
Re>filter schematics for modeling.
I wanted to get a better idea of the actual filter response since it's so close to the port tuning?
edit>Normally with sealed wideband drivers you don't care too much about close in as long as the HP&LP are balanced and operate away from driver resonances. but not the case here.
We are talking about hopefully getting 6-10 dB of out band rejection by fine tuning your port and box alignment to the HP filter corner.
mitchyz250f said:Can you make recommendations for the crossovers for the midbass? I was thinking based on your comments I could tune the box to 83 Hz and crossover at 106 for some added protection. Does this make sense?
Yes this is a much better way to go.
Post plots and look at adding the filter to unibox or watever you use to box model.
The chips are resistor packs. You can make your own with a DIP plug and your own resistors for any frequency you desire!
So how do we calculate the R values?
If the port goes unloaded around 80 Hz and we set the filter corner at 160 Hz. 3 pole filter is 18dB/oct = -18dB out of band rejection of input levels at 80Hz.
Please help me understand what you are saying. I understand the cone unloaded at 80 Hz. But din't really understand anything else.
infinia [/i]So how do we calculate the R values? [/QUOTE] Was asking for help to modify your filter chip pack [QUOTE][i]Originally posted by infinia said:If the port goes unloaded around 80 Hz and we set the filter corner at 160 Hz. 3 pole filter is 18dB/oct = -18dB out of band rejection of input levels at 80Hz.
Third order crossovers
3rd order filters have a 60 dB/decade (or 18 dB/octave) slope
Octave means, when the frequency changes by a factor of 2.
or 18 dB over the range of freq when it doubles or halves.
160Hz/80Hz = 2 or 1 octave so we have 18 dB rejection
see http://en.wikipedia.org/wiki/Audio_crossover
R = (7.2*10^6/Freq)
To verify, this formula would put the resistor in his 90Hz module at about 80k ohms.
At 160Hz, that's 45k ohms.
Or, just read one of the resistors in the 90Hz module, and scale linearly in inverse proportion.
1% resistors recommended, 1/4W. Filter is a SVF, so it uses 6 resistors to take care of LP&HP simultaneously.
Forgot to mention, it's a 14-pin DIP plug.
Hi Tim
Thanks for the info.
That makes sense there are 6 resistors.
I assume they are 1/8 W metal film 1% and can be had at
http://dkc3.digikey.com/PDF/T083/1814-1816.pdf or....
see web site for standard values'
Just a little background so that you guys (TSmith1315 and Infinia) can understand your audience (me). I have a BSME and really wish I had paid a lot more attention in my EE101 class which I took in 1976. So I knew very little and forgot it a long time ago.
Typically people discribe crossover points by the 3 db down point. But Infinia I believe is describing it by the 'filter corner'. I think this is the theoretical initiation of the down point, the knee. So an 18db slope with a corner point at 160 Hz is 18 db down at 80 Hz. Where as when people use the 3 db down method you are 3 db past the 'filter corner'. Is this correct?
Is there something that you guys want me to build or test? We have EE's here that can help me do some stuff like this (for a price of course).
Infinia-Are you saying that if I want to tune my box so that the crossover has reduced the signal 6-10db prior to 80Hz?
Hey, I'm right behind you there. If I could just remember a tenth of the math I learned...
Anyway, there are one and the same. Corner, knee, -3db down point, etc. Different Q values have different responses around this point, so it makes sense to define them by the -3dB (resonant) freq rather than where they depart from unity (0dB).
- General Interest
- Car Audio
- Porting a JBL 2123 for midbass duties
