port question
I can explain it but I need a better understanding of what you are doing.
mostly how big is the box volume, what tuning have you chosen?
is 3.6cm the radius of a pipe or a side of a square port?
edit: what driver are you using?
:scratch1: wait am i getting confused here..
if one port has 10x10 by 55 how can four ports be a lower mach and be 3.6x20 each??? is something wrong with the program? cos you could fit 4 40mm pipes into a 8cm square with space to spare, so if there is a obvious reduction in the overall size of the vent hole, and the length is shorter to match... how can the program say the mach of the 3.6mm by 20cm pipes is less??:scratch2:
does length effect mach 😱 this makes no logical sence, going to have to think about this
Good question. And a problem with simulator assumptions. I don't
know the answer but its probably to to with end corrections for the
real effective size of the port and those corrections not considering
multiple port interactions for closely spaced multiple ports.
rgds, sreten.
But even so its not enough to explain the discrepancy I think.
rgds, sreten.
Collo's DIY Subwoofer Enclosures
Is good reading, but note your not building a subwoofer, in reality
a low tuned port needs to be able to handle 10% to 20% of the
total power available to a bass / low mid unit.
I just sim'd a generic driver in a generic box using 4 round 3.6cm x 20cm ports vs. one 10cm x10cm by 55cm port. The velocity of the 4 smaller ports is almost three times that of the larger single. Something is wrong with your sim.
Length effects tuning frequency in conjunction with cross area. Cross area alone determines mach.
edit: 100cm^2 is 2.59 X 38.48cm^2. So the velocity will be greater than 2.59 x that of the larger port.
sorry for the inactivaty, im off on holiday tomorrow, had to force myself to take a break
igot my driver units and am overjoyed, i had to plug em in and test them free field at a low volume, they all work fine
the build quality of these drivers is superb, esp the midrange, tweeter dosent look lovely, because its faceplate is plasticy
now i have observed something that could throw a spanner in the works,
for the mid its fine because it will be sealed
but for the bass,
in all drivers i have seen the spider coveres the voice coil
for some reason with these you can see the copper coil, and the magnet gap, im just wondering, in a ventet cabinet could this not get bunged up overtime with dust as other bits,
see pic
image hosting
my final box, before i put pencil to wood
tuning volume 90liters
dimentions 75x55x35external 70 50 30 internal
box volume 105liters
port tuning 27.5 (low note on piano)
square port...
dimentions 36x10x10 internal 33.5x15x15external
port volume 7.54liters
left for bracing and driver 7.46liters
strait firing port 180rotation from woofer, inother words lower back of the box
material all 25mm mdf
all things concidered over time, i decided to listen to those who said dont curve the port. i also decided to go between peoples views on not tuning too high or low and decided on 27.5hz
all bracing as it ony need apply stability to its dimention will be 2.5x2.5xtbc sections of spare mdf in a grid cross pattern with a t section for the woofer
as a guess i am leaving 1liter for the woofer itself
everything in order?🙂
There are two advantages of having round port; by having front and back of port flared 1. turbulances will be reduced 2. you can make port significantly shorter. This is in regards to stright ports. If you manages to make contoured port, that gives 3. increased maximum output from the port by up to 8dB or so..
thanks for the reply
i can round it off a 0.2-1cm with a router. but i like the idea of a square port for some unknown reason i just do
also none of the above where advangages of a round port, more a flared one
Sorry to (have a) say in your thread but I think you have a too big of a speaker.
I would point more for 71 Liters internal volume (SEAS CA26RFX) with a natural more rounded output curve at lower frequencies. Tunning frequency is fine for this internal volume.
In fact after simulating your 90 Liters (int. vol) box it doesn't look too bad. For sure it doesn't look like a sealed as you mentioned in your firsts posts. Probably it will not sound that good (take it with a grain of salt). So if I'm right, I hope not, you will end up with a sealed cabinet with your port(s) canceled from necessity. Shall see (with respect for others designs) maybe only what a final audition can tell.
making the box slightly larger raises the efficency slightly. obviously the cone will be moving a tiny bit more to compensate.
can you provide a reason why you think the box is too big. what makes you think that it would sound bad? im not understanding, :boggled:
im happy with the final box as long as the port has enougth space, :scratch2: which i am still being an impatant beaver and awaiting conformation on... :xfingers:
