Maybe you have not actually read what I wrote. You might have read the first sentence and thought I said that you can tell the difference between hi-res and redbook in a blind test. In that case, go back and read again.
You may wish to see who is posting things like this under your handle:
That's a direct and uncensored quote. Maybe your account has been hacked? Or did you mean to say, "When people are told that something is hi res, they think it sounds better, whether it does or not?"
As I said in the beginning in of this thread it is scientifically proven that the average person can detects the difference between hi-res and redbook material. That is a fact.
I'll just correctly quote myself then as you can't seem to manage
What I didn't mention was that these tests are psychological tests.
The subjects where informed which material was hi-res and which was redbook, regardless if they were or not.
And sure enough, most people could easily identified the hi-res material a being better.
So what I actually said is that only when subjects are told which one is hi-res and which one is not could they tell the difference but in that case they were very consistent.
Maybe you're reading impaired and in that case you are excused but I cannot release data that I'm not allowed to release.
Details of the experimental method I'd find much more interesting than the data produced. Do you have any?
Pretty straight forward really. When available a hi-res recording and a redbook recording was used. When a hi-res recording was not available the redbook version was used unmodified. Before each session which one to be designated hi-res and redbook was chosen randomly. Before playing each sample subjects were told which quality the recording was regardless if it was the opposite and given a brief instruction on what in particular to notice. These instructions were designed specifically with positive language for the hi-res description and negative language for the redbook description. Subjects gave consistently more positive feedback on the one they were told were the hi-res recording. That's it really. There should be a paper out on it that will be publicly available in a few months.
EDIT: Forgot to mention that the instructors that read the instructions to the subjects were not aware it was a psychological test. They actually thought the material they presented as hi-res was hi-res regardless if it was actually the case.
Doesn't sound particularly rigorous for something claimed to be 'scientifically proven'. But thanks anyway for sharing.
<edit> On further reflection the details of this experiment don't correspond particularly well with your original claim, unless I'm majorly misunderstanding something. Your experiment as described seems to be testing for the placebo effect of being told a recording's hi-res. Rather different from the original assertion about 'detecting the difference between hi-res and redbook'.
It was designed to prove the power of suggestion.
The point being that we need hi-res recording in the same way we need expensive "quality" wine, designer clothes, and everything else that makes life worth living. We need it because we think it is better and makes us feel better about ourselves when we have it, listen to it, or drink it.
ISTM your argument is flawed. Your experiment showed those particular subjects just needed a convincing story for how and why something's better, quite orthogonal to it actually being better.
I don't see the difference. Enlighten me.
Enlightenment is not something someone else can give you, its something you have to see for yourself.
Gizmodo wants the research? Well, they'll have to pay to be an AES member like everyone else.
Can you cite a few papers (no preprinted) to support your claims? None of this childish "It's true. Go look it up."
se
Oops. Should have been "no preprints" above. Though after reading Saturnus' subsequent posts to the one I quoted above, I'm sure I'm not going to get any sort of answer. Just more empty hand-waving.
se
se
LOL - yes, so seems most of us actually agree with your conclusion, we just question how you arrived at it.
Am I right in summarizing your position as "there is no technical advantage to hi-res, and it doesn't actually have to be hi-res - as long as the listeners *believe* it is hi-res, they will enjoy it more than "normal CD quality"?
Unfortunately he may end up being the only artist who actually creates some of these hirez music files.
Studios will record in 48/24 or 96/24 just because that makes sense for their processing. Artists will record in wharever format the studios record in.
Problem is that once you go beyond "more than good enough", there is no upper limit. 2 MHz 64-bit recordings, anyone?As far as the sound quality debates, I suppose if you use the highest rate out there at least you sort of subdue some debate over "it's not good enough".
Well, PCM (not just specifically wav), yes, but 32 bit float doesn't give any more accuracy than 24 bit fixed point.192khz/32bit float .wav files are certainly at the top end of the digital recording scale right now
The FLAC is unpacked to raw PCM (not a wav file) because that is what a DAC uses - it might then process that further depending on the internal architecture (upsampling, delta-sigma etc).I'm curious to know if the FLAC is actually unpacked and the player actually is processing a wav file to the DAC output? Anyone have any technical info on that?
96/24 (and 48/24) is what pretty much everybody uses, and for a good reason. Float doesn't add any value, and DSD has to be converted to PCM for processing anyway.Most polls of recording studios opt for 96khz/24bit these days for tracking and processing at the mastering stage. And maybe the DSD and 384khz/32bit crowd will have some arguement, but that might be something for future debate anyway.
"It's scientifically proven that with the power of suggestion people will detect the difference between hirez and redbook."
Wow. What a discovery! 😀
True of course, for modern digital studios, but someone still needs to make these FLAC files and get them up online by the time they start to ship the players. And there is a lot of origanal recordings not in the digital realm.Studios will record in 48/24 or 96/24 just because that makes sense for their processing. Artists will record in wharever format the studios record in.
It sounds like Neil and several other artist's like Tom Petty may have created some material already. Maybe something is available now for review. Or do we have to wait until October?
I see the content to be the main factor in all this. Question is how the original masters get converted and from what source and will that info be released with the files.
Hehe why not 10Mhz/128bit? Maybe we'll all hear a difference then?Problem is that once you go beyond "more than good enough", there is no upper limit. 2 MHz 64-bit recordings, anyone?
Yeah, well that seems to still be a DAW engine argument though right? I mean FP is just a nice big container for buffer overflow. Some say it's needed and some argue it's not needed. So we just get back to the same debate.Well, PCM (not just specifically wav), yes, but 32 bit float doesn't give any more accuracy than 24 bit fixed point.
That's what I thought, so the FLAC file is merely the transfer container which works because it will compact the PCM wav without loss of data?The FLAC is unpacked to raw PCM (not a wav file) because that is what a DAC uses - it might then process that further depending on the internal architecture (upsampling, delta-sigma etc).
So all we need now is to figure out and agree that 192khz/24bit PCM wav is as good as it will ever get. And maybe that can be a new final audio standard.96/24 (and 48/24) is what pretty much everybody uses, and for a good reason. Float doesn't add any value, and DSD has to be converted to PCM for processing anyway.
There will always be MP3's, CD's, cassettes, and records to still choose from.
Have you looked at HDTracks and Qobuz?
Yes.That's what I thought, so the FLAC file is merely the transfer container which works because it will compact the PCM wav without loss of data?
96/24 and even 48/24 is more than good enough - and for actual end-result distribution, 16 bits is actually fine.So all we need now is to figure out and agree that 192khz/24bit PCM wav is as good as it will ever get. And maybe that can be a new final audio standard.
Agree Julf.
And see also here: 24/192 Music Downloads are Very Silly Indeed
(The person also mentions that initially Neil Young apparently talked to Apple for a joint venture).
Jan
Jan
Agree Julf.
Jan
I've read this article before as well as watched the video on digital sampling and it all makes perfect sense and is a factual example of the science in digital audio that is well understood.
From everything said there, 44.1khz/16bit is as HDef as it needs to be right?
Anything beyond that is lost on our ears.
If 44.1khz/16bit is "perfectly good enough" for human hearing, then why are there so many people here on DIY building DAC's, converters etc...using 48, 88.2, 96, 192, 384, DSD and so on constantly seeking higher and higher rates and searching for higher and higher quality? It must be delusional and completely subjective to claim these sound better and more HDef...right?
I just don't see the point?....and then the endless debates over something that seems to have been solved years ago?
Also if 48khz/24bit gives us a slight extension beyond 24khz and a little better dynamic range and lower noise floor that is not even needed and why is that not good enough?
I don't have any arguments, just trying to wrap my head around all this...
I hate how people so often resort to the "delusional" hyperbole, as if to imply some sort of mental illness.
It's simply humans being human. While we don't know everything, one thing we do know is that it's trivially easy to get humans to subjectively perceive differences even when there are no actual differences.
se
