Poll..anyone interested in an Aikido linestage PCB group buy?
Try a 0,22uF or something as C1 (With 600V rating). If you have a couple of 0,22uF or something. Start with that and keep adding until you have the required voltage.
Remember that your psu needs to be connected to a working circuit. Otherwise there is no current draw and therefore no voltage drop over the choke and resistors.
Kind regards,
Bas
Thanks Bas!
Another Q? When using a separate transformer for the Aikido tube heaters (which I want to run AC) it is a center tap, would I also hook that to the same heater bias connection point as the resistor ends of the other one?
Thanks in advance for your assistance!
andy
high voltage
Hi Bas,
I now have a total of 128uf attached to C1 which has lowered my voltage to 342 volts. The Hammond is rated at 275-0-275 but I am getting 304-312 volts from it. Any more recommendations to lower it to 300 volts? More capactors? Different transformer?
thanks for your help.
andy
p.s. just to add that it is measured while running the aikido which then runs a Pass F4.
I think I made a serious error. To allow the PSU PCB to be mounted such that I could read the connection labels from under the bottom of the preamplifier chassis, I mounted the 6x5 rectifier tube socket to the bottom of the PSU PCB, such that the top of the PCB faces down, while the tube socket faces up. As such, the tube is reversed. I presume this will cause it to not work properly.
Is that the case?
Hi Kris,
Unfortunately that is the case.
Pin one will be in the place of pin 8...etc..etc.
I've made the same mistake before on a different pcb. Soldering the transformers to the wrong side...took a while to loosen.
The pcb I made a mistake on had metalization all the way trough the hole. (Not sure what the proper term is)
In the case of your pcb. Try not to heat the solder too long otherwise the pcb tracks may come loose.
Kind regards,
Bas
I received my custom transformer with the following specs:
Output 1 - 0-290 V 50mA
Output 2 - 3.15-0-3.15V, 2A
Output 3 - 3.15-0-3.15V, 2A
Output 4 - 0-6.3V 1A
I will connect the heater bias to the CT of the two 6.3V supplies. The output 1 (high power supply) is not center tapped. I will use D1 and D2 diodes. Do I need to add two resistors to the high power supply? If so, what value? Also, where should I connect the two resistors?
Thank you
Kris
Aikido up and running
I finally got my Aikido line stage up and running. Yah! I used the PSU PCB designed by Bas, used a choke, and a Heyboer transformer to run the PSU plus provide dual 6.3V heater supply.
The line stage sounds great. No coloration, bloom, or glare. Just clean, pleasing music.
Thanks all for the advise and insight.
Kris
Re: Aikido up and running
Kris
Kris,
Couple of questions for ya,
Did you use the default ratings on the PS board? ie: Caps / Resistors / Choke size?
Did you check your final voltage after it was completed?
Asking because most others have a 275 0 275 transformer and you stated you have a 290 0.
I've got a 300 0 300 ............just talking secondary HV.
Thanks,
Ron
Anybody try different size caps in C2 /C3 /C4 /C5 /C6 ?
I've got a few 68u I could substitute.
Is there a working PSUDII simulation of this board? Then I could manipulate the sizes myself. I got to the 5AR4GRAET Hybrid rectifier and C1 then Choke, 68uF cap then what?
Thanks for the help,
Ron
