PLLXO (v AXO v PXO) benefits/ Model?
One thing I've wondered about that i read in this post:
Say you have 10 k input impedance on the amp and R2 equals 100k like in the case described above, is the insertion loss of ~ 11 db the only disadvantage or will the amp also have more distortion because of impedance issues?
I would ideally like to have a fourth order low pass PLLXO, my source has very low output impedance so in the end the last resistor R4 would only be ~ 3-4 times lager than my amp input impedance, which would present very acceptable insertion loss for me ( My source has abnormal output also, I'm at the moment using 20 db attenuators so ~ 6-11 db loss would be nothing 😛 ).
However if impedance issues generates additional distortion then I would have to add a buffer, but if I only lose some signal then I wouldn't need to bother which would be very nice 😀
