how about L.Cao 6.5" non-alnico magnet?
they cost about 105GBP for a pair including postage to Europe, pretty good efficiency.
never heard them but soon I'm going to try build something using them
Supposedly they are quite nice. Good suggestion. I'd like to hear them myself.
Yesterday evening I've been digging for a while on this forum and I've found out that Karlsonator 6 - which is Your design, Greg - was rated as an excellent combination with L.Cao F6. This one is going to be the next build, probably in early December.
I will give you another vote for Mark Audio drivers in Pensil enclosures if you can use floor standing cabinets. It is a proven design that works well.
can't fault that recommendation one iota, but some basic limitations were well spelled out by GM on the first page
HI my dear friends!!!
I'm so sorry for my long absence, but lately my health's conditions have worsened, but now I'm feeling better, luckily!!!
Anyway...guys, you can't imagine how great was the surprise of seeing all these new posts!!!what a surprise, guys!!! I thank you
Wow these L.Cao F6 seem fantastic to me...and they're very, very suitable for my project.
Since these speakers have only 12 watt each and the amplifier has an output power of 10-12 watt I thought that I can use two L.Cao F6 speakers for each box.
What do you think about this idea, my friends?
Could you suggest me some web-site or some on line shop where I can buy
them , please?...I would prefer to buy them in Europa, if this it's possible, in order to spend less money for the delivery.
I thank you once again for your support and for your kindness.
Ciao
Pietro
Ciao
Pietro
I don't think you need to double up the drivers. With 10-12 watts, one is sufficient, unless you like to turn the music up really loud.
That said, it might be cool to have two drivers per enclosure. If doing this, I would build something like a Metronome or a TQWT, but with one of the drivers rolled off with an inductor as BSC compensation. IMO two full range drivers running wide open sort of destroys the point source aspect, which is a big part of the charm.
You could also run a single driver with the suggested contour filter.
I don't recall the precise specs on these. It's possible the required enclosure for two would be very large.
It appears that most people get them from the seller in Hong Kong.
Thank you Greg!!!
Please be patience with me,Greg...I'm a duffer researching in the web:would you mind giving me the correct website of the seller in Hong Kong?...Believe me: I can't find the website of this seller, unfortunately: Eek:
So any help will be welcome!!!: O
Thank you for helping me
Ciao
Thank you Greg!!!
Ciao
I don't know if there is a website. They sell on ebay. I don't have any direct experience with this seller.
anitaydavid on Ebay
With your initial requirement of 40 l maximum, I think you will be limited to one driver per enclosure. There are two versions of this 6.5" ferrite magnet driver offered, plus one more (at least) in alnico. These drivers have moderate in between specifications, and could potentially be used in a bass reflex, TQWT or ML-TL. As you get closer to choosing, I'm sure someone could help you with a cabinet design.
Tang Band W5-1611SAF 5" pdf
Erfahrungen mit dem Tang Band W5 1611 SAF, Lautsprecher - HIFI-FORUM
google here
Italy Axomedia: Axiomedia - TB-Speakers - Altoparlanti 5"
This FR works great in a reflex 12.5 L@44 Hz, 2 ports 3.4cm internal diameter with 19/20cm length (18.16 cm2, tot area of ports). For 1x port: 5.7cm x 28 cm.
Give more 1/2 L to 0.75L for ports and 0.4L for Driver Displacement on the net volume of the cabinet making it a ~14L net.
google here
This new one with paper cone & gold phase plug should be even better, but I haven't listened it yet
Blue planet acoustic | 5" wide range drivers | DIY
i'm adding myself to the group advicing L.Cao F6.
recently i finished a pair of them in a big BR box, the old plan suggested for their predecessors Diatone P610. I built them for a friend, reading good things about the drivers.. i'm not a fan of bassreflex enclosures but it was a simple and well known construction.. and in the end i liked it much more than i expected. i used very little damping combined with a 'tozawa resonator' hanging in the center-axis, thanks to the bigger dimensions the sound wasn't choked and because of minimal damping (but more diffusion) bass wasn't muddy. the drivers are small but don't force them into a smaller enclosure, they shine when they have a space to breath in.
- Full Range
- Please I need you:Full Range with high efficiency
