Planet Audio PL4000.1D gate resistors
I'm in need of knowing the correct gate resistors for a Planet Audio PL4000.1D plus 2 others.
R20 TO R19 FOR Power supply side using 110n8f6 and R11A and R10A.
I don't know what or how to check deadtime is?
Plus on another note: I read that you like when people put testing equipment on their sig but I can't find where my sig is. I'm so tied I didn't sleep all night and I bet it's looking right at me.
Well... I can't find it either. 22 ohms won't give much deadtime.
The IRF3205 is very similar and works with 47 ohm gate resistors.
I don't know if this supply is regulated but if it's NOT, you can replace the FETs and gate resistors. Power it up at idle and check the temperature of the PS FETs. If the run cool, the gate resistors are OK. If they run hot, the value will have to be reduced.
Those work great. Heat didn't get above 92 at idle and then I pumped a little music and the IRF3205 stayed around 100 with no heat sink. Do you know if IRFB31N20D be swapped with IRF640N? What do you look for when to see if you can change mosfets?
Yes. You need to replace all 6. I don't have a confirmed drop-in replacement but I've been told that the IRFB38N20D worked. What you'll need to do if they run hot is to adjust the CCS on the driver board. It's covered on the Generic Class D - Type 2 page of the tutorial if you have it.
