Planet Audio PL4000.1D gate resistors
I'm in need of knowing the correct gate resistors for a Planet Audio PL4000.1D plus 2 others.
R20 TO R19 FOR Power supply side using 110n8f6 and R11A and R10A.
Well... I can't find it either. 22 ohms won't give much deadtime.
The IRF3205 is very similar and works with 47 ohm gate resistors.
I don't know if this supply is regulated but if it's NOT, you can replace the FETs and gate resistors. Power it up at idle and check the temperature of the PS FETs. If the run cool, the gate resistors are OK. If they run hot, the value will have to be reduced.
