Pioneer SA-7300 advice needed.
Joined 2009
I'm fixing this amp for a mate and have no experience with these power module type outputs? The amp was dead except for the power light when I got it from him,he said he got it from an old bloke who had it from new. The main filter caps 8,000uf were bulging and read 620uf and 510uf,so I fully recapped the whole amplifier.The right channel power module SP-40W had failed,I took it out to measure it and found pin 3 had no reading.What I need to know,in case I blow up the new SP-40W module is if Q9 the transistor that has its connector going to pin 6 is going to read -1.2v (as in the schematic) when I install the new SP-40W power module? At present Q9 collector reads -35.6v? Ive checked all the discrete transistors and they read OK.There was one completely failed cap: 100uf,25v and another 100uf,25v badly bulged reading 200nf, both of them on the power supply to the failed SP-40W. I opened up the failed module to have a look. I could make out burn marks on the tiny wires going into the semiconductor at the top of the photo.These modules are as rare as hens teeth and I need to know its OK to install the new one without blowing it up!
Without the module in place you will see near rail voltage at pins 2 and 6. If you would like to test that the front section is working as far as DC levels are concerned, jumper pins 2,4,and 6 of the modules socket and measure the voltage there. It will be somewhere between +/- 1.2V.
they contain 2 predriver transistors 2 power transistors, 2 .33 ohm resistors to output
and the bias network. the bias is 3 diodes plus a resistor.
the driver is shot. 1.2v is the correct voltage at the input pins.
STK 0050 is similar
Sorry about the late reply.The email went into my junk folder for some reason? What do you mean by testing the front end? I cant work out what you mean,do I use some jumper leads to connect where pins 2,4 and 6 go to, then measure the voltages from 2 and 4 then 4 and 6?
When you install a new module (if you can find one, which shouldn't be possible), power the amp up with a dim bulb tester (google it) to remove the risk of things blowing up.
I found a used one on fleabay the first time I looked for $12.50 (it had been tested) with free postage.I must've been lucky. Don't worry Ive had a DBT for years and its saved me a lot of times.
What do you mean by jumper pins? Does that mean I use jumper leads on those pins somehow? Honestly I cant for the life of me work out what you mean?
all that is in there. note the 5 connections on the one power output module (transistor) and 3 on other. the lower module has 2 drivers and bias network. sets 1.2v on each input pin to compensate for 4 x .6v Vbe voltage.
the .33 emitter resistors to protect outputs from thermal runaway
No wonder I'm getting confused. The datasheet for SA-7300 that I have on SP40W says it has 4 diodes in series 5 resistors and 2 Darlington transistors,one is NPN the other PNP? The main thing is that its going to drop the Q9 collector and pin 6 voltage down from -35.6v to -1.2v when I install the module! Is that right?
