picture of cviller f5 v2.0 boards populated
dj , in that case 😉 i don't have a set populated to photo , but i've a empty set i'm looking at .
holding them so the printing is right side up Q6 is on the left and assuming you're using the ZTX450 , the "flat side " should be facing you . Q5 is on the right and assuming ZTX550 the "curved side" should be facing you .
hth
cheers Woody
I had this same issue a while back but never saw a photo either.
This PDF does have some info you might find handy if you haven't already seen it.
I also found this photo of some use.
Best of luck
Dean
