I have built a 10-channel power amp using LM3886's on Rod Elliott's PCB. I have a big shared power supply (1kVA transformer, 112000uF, etc).
I am getting between 13 and 50mV pk-pk of sharp spikes on the output (sounds like mains related buzz), co-timed with the charging spikes on the supply rails (about 350mV pk-pk sawtooth on 32V rails). Channels where the noise is below 20mV pk-pk are almost acceptable, but the one channel that is up at 50mV is a real problem.
Does anyone know where this pick-up is likely to be happening, and what I might be able to do to lessen its effect? Power supply rejection on the LM3886 is supposed to be 85 to 100dB - I am certainly not achieving this. Any clues as to why there could be such variability between channels? (doesn't correlate with position in chassis relative to power supply)
Many thanks
Jamie
Many thanks
Jamie
