Photo Gallery
Here is my Velleman K4040 kit ready for final bias adjustment. :)
It took me a weekend or about 15 hours to put her together. Easy kit to build with nice finish in black and chrome.
I’ve got the work log here http://www.veiset.net/k4040/k4040wl01.html (in Norwegian only, but the pictures tells the story)
The new look of my KT88 SE amp
¿Remember the amp I did in a chassis made with recycled parts taken from the bin?: link here
Now I have mounted it in a standard 1U rack box.
The KT88 is runing in triode mode. I love the sound! :)
Upupa Epops said:
Guys, have you children ? Do you know, that exist in safety norms something, which is called as " hammer test" ? Do you think, that tube have temperature lower than 60 ° C, which norms prescribe for finger touchable parts ?
you're right. it's funny, but we have to foresee it, leave out any trobles. my tube ampl has +75 C. it's realy dangerous
Sweet!:up: :up:
What is it with you Canadians and moving parts... ;)
I met a Canadian DIYer from Quebec? (I forget) a couple of years ago at one of those audio shows in NYC. He brought down his turntable he had made to use as a source for one of the rooms. The turntable was machined in aluminum with carbon fiber throughout; plith, platter, arm... The turntable was isolated by some form of liquid damping at the four corners.
It was the most beautiful turntable I had ever seen. And unique...the only one made.
Although form must follow function; no DIYer should be afraid of making something too beautiful. :angel:
Hi Everynone! My first post at this interesting forum.
I could start with following suit - showing off some of the hardware I have build:
First a pre-amp using ECC82
Power supply is in a separate box
Next out is a OTL headphone amp based on 6SN7
Power supply uses tube rectifier and electronic regulation.
Finally, an OTL for headphones using 6AS7 + E88CC
More will come - current plan is an SE with 807's...
