Sorry for offtopic, but tubes involved![]()
Awesome nixie clock!
Did you build that yourself? What particular Nixie's did you use?
I have 4x russian made IN-12A nixie's that I plan on making a clock with but haven't gotten around to it yet.
Thank you!
The tubes are also IN-12's. The clock control unit is a kit from Claus Urbach, when you google his name you will find his onlineshop.
The housing (aluminium and wood) is selfmade. Realising an own control unit is very complex and requires skills with programmable ICs.
Yes, that post containing the very, very nice looking aluminum faced and wooden cased nixie clock is COMPLETELY off topic.
To rectify this egregious and flagrant flaunting of the rules, I will gladly dispose of the offending item for you. Please send the nixie clock to me immediately and I will get rid of it for you (please package it with lots of cushioning and mark it as "gift" for the customs officials).
And it will serve two purposes too... I noticed the article in the background mentioning, "Fire starting on the first floor". Disposing of it properly will protect you from fire that could happen from this nixie clock (don't worry, I am a professional).
Don't laugh folks, I am hoping that this will actually work one day.
very very nice
NIce offtopic, Watchtfels666! I like tubes and nixies as well:
perys | perys - Nixies ? rajce.net (power clock)
perys | perys - Jadis-JA-30_mk2012 ? rajce.net (tube amp MkII - lowered hum below -90dB)
There are few pictures of spectra measurement added for Mk_2014 version /less NFB about -2,5db only and lower quiescent current of 6550s/:
(white is PCcard background)
- lower hum -85dB @50Hz, better than -100dB other freq.
- measurement @19+20kHz and @20kHz
Aikido preamp.
Driven by 6N1P and 6N6P, output caps K40Y9, after few months I will change caps with Auricap's which I have them already.
Is there a Denon DCD-685 CD player? If so, it is worth to rebuilt.
You can replace its poor opamped analogue stage by tube based one, and the player will sound awesome. I did it many times, and recommend it for you. Here are some pictures:
![frontal%20view.jpg](https://lh4.ggpht.com/_o-j1QGIOpHQ/Sk1j9B_uLoI/AAAAAAAAACs/oW8QBrssU4U/s800/frontal%20view.jpg)
![lateral.jpg](https://lh6.ggpht.com/_o-j1QGIOpHQ/Sk1j9BBU3tI/AAAAAAAAACw/b3cwAeO9QYw/s512/lateral.jpg)
![PSU.jpg](https://lh6.googleusercontent.com/-aberKpYHwSE/UuUzdKomZaI/AAAAAAAABH0/hPQnR5ITDWA/w505-h580-no/PSU.jpg)
You can replace its poor opamped analogue stage by tube based one, and the player will sound awesome. I did it many times, and recommend it for you. /tuB8yGZxoD50GcKV_VHY0fr6Jxg_BV7BSbE-UrMMZzE=w800-h461[/IMG]
Yeah DCD 685... Works good, just sometimes CD drawer get stuck, like is trying to open and after many times open/close will open or a "gentle" slap in chassis, the drawer opens
Nice work in your cd player, which tubes you are using? I can see in pcb SRPP.. (will you share the design) Can 6N1P or 6N6P do the job?
My Aikido, I like sound of it. Really its worth any cent I invest on it.
Makes music so rich and lifelike, especially classic rock when I listen.
I'm using 6DJ8.Yeah DCD 685... Works good, just sometimes CD drawer get stuck, like is trying to open and after many times open/close will open or a "gentle" slap in chassis, the drawer opens
It's only print on PCB. My circuit is common cathode tied to the cathode follower. I'll share the circuit when I'll find the drawing. You can use (with some mods) the line stage from Klimo Merlin preamplifier also.I can see in pcb SRPP.. (will you share the design)
Yes, they can, but I dislike both. I used to replace 6N1P by 6CG7 and to replace 6N6P by 5670 or E182CC (Warning! Different pinout!). Replacing 6N6P by E288CC in my ukrainian monoblocks gave great sonic benefits.Can 6N1P or 6N6P do the job?
I believe you. I'll post the pictures of my handmade tube preamplifier soon.My Aikido, I like sound of it. Really its worth any cent I invest on it.
Promised photos of my tube preamplifier:
Great!
I check your site, very nice gear you build.
regards,
bekim
Great!
regards,
bekim
Thanks. Tube RIAA preamp inspired by Audio Research SP6 is the next piece on my workbench.
Ampli SE config.2 x 8W
My SE amplif (paralel)2 x6P6S and ECC83 driver.
- Tubes / Valves
- Photo Gallery
