PHONIC max 860
3 MAR6
I have 5 Mar6. 3 of them�@have recently had the same problem.
The two of power fuse are blown in the amplifier. And the other one gets easily heated with no signal. I need a manual or a diagram to seek the cause. Because I'm a new member, I cannot write directly to every one. Please help me to solve the problem.
Thanks!
Single Channel
Hoping to get some help with a fairly straightforward issue. I have a Phonic Max 860 and want to use it with a 300W single Dynacord speaker for monitoring. If I used it bridged, it outputs 600W which might damage the sxpeaker, but can I use only one channel without damaging the amp by having no speaker connected to the other channel? Thanks.
Yes, power supply voltages and just want to see differences between MAX1500 and MAX2500 power supplies. I have toroid transformer from Behringer EP2500 and planing to put it in to Phonic MAX1500 if it is possible (voltages are cca 4x38V AC).
Service manual attached.
Sorry only one page attached, as the whole file is too big...
Sajti
Thank you for schematic but I already have it. In service manual I have described all tree models but with only one schematic attached. On that schematic voltages are +90,+55,0,-55,-90 and I have found those voltages on my Max1500 but I do not know voltages on MAX2500 because it is not described separately in this service manual. On this sheme I see voltages +100,+55,0,-55,-100. Is it correct value for max2500?
