Phoenix Gold XS4600 blown trace
Q7 63 not 6.3
Q8 63 not 6.3
Insert a single 10 amp fuse in one of the two fuse holders and confirm that you read 0 ohms across the other fuse holder (that now has no fuse).
Do you read 0 ohms between the source terminals of all PS FETs to the ground terminal of the amp?
Do you read 0 ohms from the drain legs of the PS FETs to the B+ terminal?
If that's what you have, Connect the ground and touch the B+ to the battery for a second, or so. Does the fuse blow?
