Also dead unit for sale in .au (west coast) for $45AUD (c. $30 USD, 25euro)
Couldn't resist. Got one channel up and running already but the other will take a bit more work (something shonky in the pre-amp)
Also found a thread on AudioKarma.org with substitutes
Concerning the transistors, here is the cross reference table I used with succes
(thank you very much Echowars )
355N -> MJ15024G
357N2 -> 2SC2238
357P1 -> 2SA968
263N6 -> 2SC2632
148N3 -> 2N3904
158P3 -> ???
383P1 -> 2SA835
383N2 -> 2SC1124
213N1 -> ???
360P1 -> ???
CA3100S -> HA2525 (not tested !)
D206 -> 1N4148
The famous R232
Popping the top shows R232 has been replaced - indicating I need to check K303 for welded-closed failure on one side
And then onwards as per Pat66's instructions on Audio Karma
Nice to have the path marked out!
Couldn't resist.
Relays are working so it's something else.😕Popping the top shows R232 has been replaced - indicating I need to check K303 for welded-closed failure on one side
Philips AH578 schematic here :
https://www.diyaudio.com/forums/solid-state/367494-latfet-amp-based-philips-ah578-3.html#post6525315
