alexcd said:Sounds a little like trial and error to me which is a perfectly good engineering tool cuz I use it all the time. It helps to start with an educated guess is all. (talking about my own methods)
Its does genuinely work first time and everytime with the formula's listed above this post.
Good work so far. Take lots of pics.
I'm doing construction in two parts, the bottom section and the top. These will eventually meet after I've done all the angle work that has been discussed.
Bottom section:
Top section:
I've gone a little overboard with the glue and it squeezed out when clamped together. It looks a mess at the moment but all the excess will sanded off with the palm sander, the rest of the joints will be hidden behind another layer of 18mm MDF and then a 9mm MDF skin to provide a virtually joint free surface to spray.
And here's the mitre setup and the resulting cuts, its very easy once you actually know what you need to set it at:
Ant,
Are you going to still do the cement baffle? Do you have any idea how yet? I'm confused and really need to see it done.
thylantyr said:I usually draw what I want in AutoCad and then let the software dimension it. Yeah, cheating right? /lol
I've got an old copy of Autocad that I sometimes use but to be honest its a real pain setting these types of cuts that I'm needing. Easier and quicker to just use trial and error in that case.
What I wanted was something that could be used very quickly and with variable angles. This will now make future stuff much easier to build.
alexcd said:Ant,
No cement baffle unfortunately. Have a word with Scott again since he's done that type of thing before.
alexcd said:Off topic but where do you live? Those trees look tropical.
I wish!
I'm in the UK, the garden has a tropical flavour though with stuff like palm tree's and other such shrubbery.
If you look in those shots, you'll see its doing the usual UK weather ie. raining.
I spent 8 weeks in London a few years back during spring time and it only rained once. The people were in shock.
ShinOBIWAN said:Here we go:
Cut angle = arctan (sin ( lean angle ) )
Bevel angle = 10 * (0.5 * arccos (sin ^ 2 ( lean angle ) ) )
Thanks go to Mark and Charles for that.
Wow, ok, I think I get it now from the explaination you posted. Sorry I wasted your MDF bits with my attempt. I guess I've just seen "Good Will Hunting" a few too many times 🙂
m0tion said:
Wow, ok, I think I get it now from the explaination you posted. Sorry I wasted your MDF bits with my attempt. I guess I've just seen "Good Will Hunting" a few too many times 🙂.
Hey, no worries.
I was going to try something anyway and MDF is very cheap. The important thing is I learned something else! 🙂
Latest pics:
Woohoo! B&Q budget routers rule 😉
I think I have 3 now, one lives with a 1/4" halfround bit in it as it saves time resetting the depth each time.
Looking good!
Looking good!
ShinOBIWAN said:Still haven't bought a port yet.
That comes later and is the reason why the base is missing.
Ah! So one of the braces will be "chewed into" a bit.. 😉
..and indeed - Looking good! 🙂
BlackCatSound said:Woohoo! B&Q budget routers rule 😉
Looking good!
Yep think it was £30, I use it it a lot too.
The yellow one has more torque than an F1 car, think its 1650w/25,000 rpm its 'kin scary when its wound up anyway, but its so damn weighty. Only thing I use it for now is the driver cutouts, the rest is the little grey thing that weighs nothing and is easy to handle.
And thanks.
BlackCatSound said:Scott, build first, think later 😉
You've gotta laugh 'ant ya. Spent all that time with the fancy drawings, planning and having the wood cut proffessionally and then I still 'uck it up 😀
EDIT: Actually in my defense I was drinking whilst doing all the bracing. By the end I was half p1ssed. Nothing like a good drink whilst woodworking, do it fairly often because it helps to steady my hands 😀
T'was simply a change of artistic focus! 😉
Hmm..
The good: Steady Hands.
The bad: No fingers.
ScottG said:
Hmm..
The good: Steady Hands.![]()
The bad: No fingers.![]()
You know what Scott, in all the time I've been mixing power tools and the odd beer I've never once injured myself, I've injured the work I've been doing but not myself.
Believe in jinx's? My next progress post will now be a story about how I spent 4 hours down in A&E. 😀
- 'Perceive v2.0' Construction Diary
