'Perceive v2.0' Construction Diary
More progress:
What tools do you use to cut out your bracing? I have used jig saw and table saw, niether with great results. For table saw the blade is raised to full hight (3.75" or so), but you can still see the little slits on 1 side where the bottom of the blade goes a bit further. While the jigsaw... not perfectly straight, maybe a guide would help, but...
Josh
edit: Looking at the last picture, it looks like you have a clamping guide holding the sides, I have that guide as well, perhaps that is what I need to use when cutting out bracing.
Josh
After initially cutting using the table saw, the bracing was then cut free hand with a jigsaw. A bit of practice, a good blade and its possible to get straight cuts. If you setup the guide it would take a good while to do all those.
Great concept and excecution.
Somebody has to ask..... What kind of display do you have and will it be effected by the magnetic field from those four beautiful woofers??
Keep up the incredible work! The finish quality of your work is an inspiration to us all!
Nate
m0tion said:
Not that how clean the cuts really matters when you're doing bracing, other than for the asthetics of your "construction pictures".
Agreed.
But can't see the point when you consider that there's virtually zero effort between a neat cut and one that looks like a dogs hind leg. I guess its all down to the individual and whatever works for you.
Nate
Hi Nate
The screen is an LCD type which aren't affected by the fields. Although the screen housing may vibrate and buzz a little so could have to isolate it if that turns out to be a problem.
And thanks for the nice comments.
m0tion said:
Shin:
You mentioned the B&C drivers were of particularly high mechanical quality. How do the XLSs compare to them build quality wise?
Not particularly impressed. Build quality is below the B&C and things like venting the pole through some holes drilled below the dustcap seem a bit amateur compared to the lovely great flared affair on the B&C. There's also a lot of slightly rough pressed metal work on the motor and basket, whereas the B&C was all machined. The B&C's really feel like you could hammer them and they'd still be fine, the XLS don't inspire that same confidence.
I do like the basket design on the XLS which is better than the one on the B&C though.
Other than that I haven't tried the XLS's at all, not even free air. I normally run drivers in but everything is a bit of a mess at the moment. I guess the first time I hear them will be in the cabinet.
Sorry not much help I know..
Pushed on a little further this evening and I found my roundover bit! Sadly I'd already installed half the bracing but doing the other half won't hurt.
You can now make out the port entrance here:
Collection of bracing ready for installing tommorow:
I rounded the edges of the MDF peices that will form the port in an attempt to smooth ineviatable turbulance:
Little more done this evening.
I'm really pleased with the driver cutouts, I was working blind so to speak as the holes had to come out in the exact correct position in order to meet up with the driver magnet braces. Fitting 4 x 10's was tight as you can see by how close they're spaced! All in all it was textbook stuff so my hat goes off to CorelDraw for helping me nail all the small details without incident.
Seeing all those driver cutouts made me realise that I'm really looking forward to getting this going. Hopefully another week or two will see the construction finished at this rate.
