Pedja Rogic 1541A DAC Custom-Wound Transformer European Union Group Purchase
I can confirm it works that way, there is also a document on atrim's website... too bad I didn't see it on time...
at least with the mains they go standard, brown, white, black, pink...
http://www.antrimtransformers.com/add_page.php?PageId=643
PS: sidenote, don't forget to mount some sort of copper foil/plate over the digital chips and then ground them with a wire. very important, go try with and without, you'll see what I mean.
I'm happy with it, nice bass and all, but a bit soft for my taste with some tunes... I have to play with the parts some more...
(for now BG 0.1 for decoupling, BG 100uF std for analog, bg 4.7 for output, mica for C124/121, dale/rikens eveywhere where important...)
Too soft ehh?
Try Caddock TO20 for I/V, TDA1541S2 double crown, Reclocker (a must) 100nf Multicap RTX for decoupling of -15v😉
I use 470R caddock,3n3 polypropylene and 220nf polypropylene (low inductance) for the CS8412 filter
Mine sounds :hot: the dynamics are the best I have heard from a cd source.
Also are you using Panasonic FC's for the large value caps in the PSU's before the regulators? I tried the FC's but they klled the sound, the bass was almost flabby so I now use standard types instead of low esr types.
All the other caps are BG's
WTF? I checked out UPS to see what shipping might be to 08077 from London for a 3kg. package and it came out to something like 60GBP, more than a hundred bucks to me. I thought it would around $30-40, which I can live with - apparently not.
That's nuts. Is there a cheaper alternative, otherwise I'll have to withdraw my name.
John
