I have a Peavey Companion guitar amp that is powered by a 12vdc/2A wall wart or by 8 ea. "D" cell batteries. I would like to replace the regular batteries with a rechargeable Lithium ion battery. I am concerned however about overcharging or undercharging the battery and causing problems for myself. I have a boombox that uses just such a system and it has a red light that turns on when the battery needs charging and turns off when it has received a full charge. Is there a economically reasonable option for installing such a system in this guitar amp? Thank you for your help!
I have no idea how well this works, I just got a new flyer in the mail and saw it advertised.
Dayton Audio LBB-3 3 x 18650 Lithium Battery Charger Board / Module 12V with Charge Protection
My DIY battery amp is powered by 4x18650 LiIon.
These are in an easy accessible battery holder mounted on the backside. I charge them with a universal 4 slot charger, each slot with its separate control. The amp is fitted with an undervoltage lockout that separates the battery before deep discharge takes place.
You buy a for-purpose battery charger. These new chemistries have complex charging needs. You can't DIY anywhere near as fast or cheap as you can buy a charger.
Now if you convert it to a truck batter it is simple. Lead-Acid is nasty to transport but very tolerant of crude charging. (Tho again, you can buy a charger about as cheap as you could DIY.)
