For those who bought the original sets, we will offer the 4 extra matched Jfets for $20.😎
got home yesterday to a package from Pass Labs, the extra matched fets! Now to wait for the article.🙂
Russellc
Russellc
Please pardon the interruption: Someone emailed me about the point-to-point deadbug photos I posted and I lost the email somewhere between webmail and Outlook. Please email me again.
- Eric
- Eric
i would settle for knowing how to get the default gain high enough for a low-ouput MC cart. Namely a Denon 103.
Though the new article hasn't come out, unless you have a high gain pre or step up, I don't think the Pearl has enough gain for a 103.
Peter Daniel's phono stage works just fine with one though. Dead quiet too.
it's cheap to find out either way. You don't have to build it with VCaps, Black Gates, and Caddocks.
Where is the Daniels version? I'm not finding on his Audio sector site, havent got responses lately, maybe he's on vacation or otherwise busy. I'll check group buys.
Russellc
http://www.diyaudio.com/forums/audio-sector/151938-phono-stage.html
he usually responds to pm's within a day or two unless he is away.
He'll be back.
Russellc
Hey everyone.
Out of people that have built the Pearl (and better, the newest Pearl 2), can anyone say where it rates in terms of the quality of sound? Are there any extensive reviews of the Pearl anywhere? I haven't really seen much.
I recently built Peter Daniel's phono and am quite happy with it - it easily outperforms my ARC PH3SE...but I am always interested to try new things.
Thanks for any input you guys might have.
Byron
Byron
Man, I cant wait for the Pearl article to come out!😱 Guess I can start gathering odds and ends that are obvious.
Russellc
Russellc
Russell,
Do you know what case you will put this in and will you put the power supply inside the same case or external? Thanks.
James
James
I wonder if the ground plane seen in the shots is duplicated on the other side of the board.
I think it is, and that the point seen near C12 serves for the 2 ground plane melting, or is it accomplished at the "PAD2 GROUND" placing ? This must be critical for some ground / noise issues.
Best regards,
nAr
Best regards,
nAr
Russell,
James
My guess is: better put toroid + bridges + 1st set of capacitors in a separate metal housing. Then have the connection to the boards that have their own enclosure, both enclosures preferably aluminium and properly grounded. This way, most silent operation is possible.
Russell,
James
I usually have Westend cut aluminum to size for me. I'd like to have the power supply in the box, but the 2 boards will take up enough real estate, so it will likely have to be in a seperate box.
The B-1 box Westend made me has extrusions for the side pieces, and 1/8 inch 6061 aluminum for the top and bottom, and back, I think the face plate is a little thicker material.
Russellc
Thanks for the responses. Russell I will have to check out those enclosures when you get them.
James
James
I have some more questions: can we use the ZVP2110A instead of ZVP3310?
It has a RDSON of 8 ohms instead of 20 for the ZVP3310, fw. transconductance of 125 mS instead of 50, an input capacitance of 100pF instead of 50 ... question is because the 2110A is very easily available here. Maybe C7 will need to be re-adjusted then.
Which is the "right" red led to use ? I mean, which is the desired direct tension needed (varies with every type of red led) ?
Best regards,
n A r
Best regards,
n A r
- Pearl Two
